Cuda Jas,
What brand of O2 sensor did you buy? How easy is it to set up?
twiles
I bought a FAST digital O2 meter, used from a board member on another mopar site.
The install and set up is very straight forward, but some welding is involved. THe meter is upgradeabe to read two sensors at one time, i am currently only using a single sensot.
What size / type Holley are we talking, what are your main jet sizes? narrow band O2 sensor?
I am currenlty runing a 750 vac secondary on a 360 / 727. I had spent a fair amount of time last year tuning the carb using a vacuum gauge after instaling an Performer RPM intake (I went from a Torker II intake).
Here are the specs on my 360:
74 Cuda with a 360,
Eddy Performer RPM intake,
Eddy torker Plus cam,
The specs are as follows:
@050 Int dur. 222 , Ex dur. 234
Lift Int .447 Ex .450
Intake Centre line 107 Ex centerline 116.
About 9:1 compression.
Holley 750 vac secondary carb.
Dizzy has been recurved, running 22 initial, 38 total all in before 3000.
727 with stock converter
8-3/4 with 3.22s
