Anyone seen these new hemis
Author Topic: Anyone seen these new hemis  (Read 5430 times)
Offline grimmey71
« on: August 26, 2012 - 11:45:03 PM »
Ive thinking about a crate hemi for a while and was holding off for the mopar 590 hp aluminum crate
http://www.speedfactorycars.com/speedfactory-cars-sema-wrap-up/
, mopar gave it a part number but as far as I have found never released it and made only one which they put in that redline charger. So I kept browsing once a week and yesterday I see this
http://www.jegs.com/p/Mopar-Performance/Mopar-Gen-III-540HP-426-Hemi-Crate-Engine/1710917/10002/-1
The jegs has the same part numbers
Re: Anyone seen these new hemis
« Reply #1 on: August 27, 2012 - 12:10:45 AM »
The original Hemi 426 block design will be less cost in the long run and have better Torque/ throw you in the seat.   :2cents:
Offline grimmey71
« Reply #2 on: August 27, 2012 - 12:14:40 AM »
These are too rich for my blood, but I am all set up for a genIii, trans/motor mounts ect....plus I want fuel injection.
Offline dodge freak 2
« Reply #3 on: August 27, 2012 - 08:29:36 PM »
Carbs make more HP vs FI and you don't have 45 lbs of fuel pressure in your gas lines. There is good reason these newer FI rides blow up more often in a crash vs the older carb cars
Offline GreenFish
« Reply #4 on: August 27, 2012 - 09:29:41 PM »
And get 9 mpg.  The new hemi will be half the weight and get twice the gas mileage and be much more streetable.
Both are cool in their own right, but it depends on what you want to do with the car.
Offline grimmey71
« Reply #5 on: August 27, 2012 - 10:46:42 PM »
My plans are to drive this thing a lot, maybe 1/3 of the year in Michigan. I had priced out many big block stroker combos and the price always ended up similar to a new gen hemi. Not that I want to open that discussion. I was just more curious if anyone has any additional info or comments on these, since I didn't hear anything about these before I stumbled upon them at jegs.
« Reply #6 on: August 27, 2012 - 11:06:06 PM »
And get 9 mpg.  Both are cool in their own right, but it depends on what you want to do with the car.
9 mpg is what I call braggin rights.   :biggrin:
Offline grimmey71
« Reply #7 on: August 28, 2012 - 12:53:08 AM »
I did always wanted to open a shaker hood on my car and see a big ass ole hemi under the hood, but my wallet say no. Even to shaker hood :bigsmile:
Offline sprecks
« Reply #8 on: August 28, 2012 - 11:36:46 AM »
Does the Jeg's crate motor come with the wiring harness and computer? You also need to think about the fuel system upgrades for the F.I. that will be required, along with the O2 sensor in the exhaust system. It's all of the little things that add to the expense of going late model conversion. I'm not trying to discourage the conversion. Personally I think it is something I want to do someday. Just have to think it through before you pull the trigger.
« Last Edit: August 28, 2012 - 11:39:08 AM by sprecks »
you can call me Jay
I've seen sicker dogs get well.
1971 Challenger Vert - 472 Hemi EFI
1969 Road Runner 440/Auto
2017 Ram Laramie 1500 - Hemi
Offline grimmey71
« Reply #9 on: August 29, 2012 - 01:46:57 AM »
Well I already have the fi gas tank and since I was buying all new exhaust it was no price difference. The computer and harness though that's the thing. Since I always wanted an F.I. Big block the price is the same if not cheaper going with new hemi. stil not sure if I am going with a jegs crate motor or if I should start seeing if I can find an engine builder who can do similar hp and tq for less money, even if I have to suffer with an iron block lol
Offline sprecks
« Reply #10 on: August 29, 2012 - 07:54:29 AM »
I did a little searching the net and found this site with quite a bit better prices. I think the engines come with the harness. They list the 6.1 as coming with the harness. A phone call would probably answer the question real quick. Here's the 540 HP 6.4 for a 13K.
http://www.moparperformanceonline.com/p-1255-mopar-426-hemi-540-horsepower.aspx
you can call me Jay
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #11 on: August 29, 2012 - 05:49:38 PM »
That's the one I would get. Try shophemi.com you can get a short block or long block and build the rst as funds allow.
Go Fast & Have Fun...
Offline grimmey71
« Reply #12 on: August 29, 2012 - 08:05:59 PM »
That is a great option, I have been looking for this P5156139, same thing with the new apache heads and has 590hp. But that seems to be never available. Plus price is a consideration. I do still have a few months till I need one lol. So I am still able to keep my options open.
« Reply #13 on: August 30, 2012 - 09:52:29 AM »
Kinda off topic, but Arias is offering a Shelby/Ford 351W Hemi conversion these days.  Stupid power out of a small block configuration;
http://www.nickariasjr.com/sb-ford-hemi.asp
http://denbestemotorsportsstore.mybigcommerce.com/products/Shelby%7B47%7DDenBeste-427-%28Click-image-for-more-details%29.html
Just goes to prove, there is nothing that produces power like a Hemi.
Offline grimmey71
« Reply #14 on: August 30, 2012 - 01:16:55 PM »
That sir is an abomination
