Author Topic: Speed control quit working  (Read 1717 times)
Offline don340-4
« on: August 28, 2012 - 12:12:22 AM »
 My speed control started failing intermittently, now it is not working at all. I went through all the electrical tests that are in the shop manual everything checks fine, brake switch & throttle cable adjustment is perfect but it just won't engage. The information in the shop manual is very limited if everything tests ok & it still don't work replace the servo. I would like to get it working again but unable to find any new parts for this 1970 unit. Has anyone had any experience taking one of these apart & fixing the problem? or where I might get a reconditioned unit?
       :wavingflag:
Don
1970 Challenger R/T SE
1970 Challenger Western Sport Special
1969 Plymouth Road Runner
2012 Ram 1500 R/T
Offline GranCuda1970
Re: Speed control quit working
« Reply #1 on: August 28, 2012 - 12:51:43 AM »
Just saw one on ebay not sure if it is the correct unit I remeber mine being round like that and I still have the mount bracket on the garage but it looks different.  :dunno:
 http://www.ebay.com/itm/DETAILED-CRUISE-CONTROL-SERVO-70-71-72-73-74-CHARGER-ROADRUNNER-CUDA-CHALLENGER-/150889389579?pt=Vintage_Car_Truck_Parts_Accessories&hash=item2321b55e0b&vxp=mtr
Offline don340-4
« Reply #2 on: August 28, 2012 - 12:48:36 PM »
 GranCuda; thanks for the link, that is the correct unit, sounds like he was able to take it apart & check the diaphragm, I think mine may have a hole in it, I'll crack it open & check it.
Don
2012 Ram 1500 R/T
« Reply #3 on: August 28, 2012 - 01:40:49 PM »
I assume both cables are good . you should be able to check for a vacuum leak without disassembling it just see if it will hold vacuum
Offline don340-4
« Reply #4 on: August 28, 2012 - 05:01:28 PM »
 Both cables are good the speedometer works fine, with the ignition switch turned on it will only hold vacuum if the rotary switch is in the off position, if the rotary switch is in the on position it will not hold vacuum.
   :clueless:
Don
2012 Ram 1500 R/T
« Reply #5 on: August 28, 2012 - 08:05:37 PM »
got me  :dunno:
Offline don340-4
« Reply #6 on: August 28, 2012 - 11:32:24 PM »
 Me too!  :dunno:
Don
2012 Ram 1500 R/T
« Reply #7 on: August 29, 2012 - 12:24:12 AM »
Never taken one apart but I bet there is a gasket in there that is dry rot. Try shooting a little squirt of penetrating oil into it pull side of the vacuum and check the vac again.
« Reply #8 on: August 29, 2012 - 01:01:11 AM »
Out of the BOOk!!
Control ring in OFF position        Turn to On position
Improper stop lamp or speed control switch adjustment                       see test and adjustment
Faulty electrical circuit        See electrical tests
Fuse Blown        replace fuse
Cable disconected        test and adjust control cable
Vacuum leak        check vacuum lines
No resume when control ring is rotated                                            faulty circuit , Rotation fully toward resume
Speed control system 1970 Service manual  1-11.
« Last Edit: August 29, 2012 - 01:04:47 AM by GranCuda1970 »
« Reply #9 on: August 29, 2012 - 01:07:24 AM »
you should not be able to engage it below 30 mph               speed control inhibitor
Service manual has somed detailed tests.
« Reply #10 on: August 29, 2012 - 01:16:57 AM »
how to rebuild a servo  :clueless:
« Reply #12 on: August 29, 2012 - 01:53:04 AM »
if it is a stuck servo vacuum control valve? Solenoid operated brake release valve system may be in brake mode dumping vacuum all the time..
« Last Edit: August 29, 2012 - 01:58:32 AM by GranCuda1970 »
Offline don340-4
« Reply #13 on: August 29, 2012 - 12:40:27 PM »
 GranCuda1970; Thank you for the Imperial club  link,  that is exactly what I needed, now I understand how this thing works or doesn't work. I think you nailed it (stuck servo control valve), I should be able to fix it now. Will update with results.
  http://www.imperialclub.com/Repair/Lit/Master/298/cover.htm
    :clapping:
Don
2012 Ram 1500 R/T
« Reply #14 on: August 29, 2012 - 01:10:26 PM »
 :2thumbs:
