Author Topic: Front window trim question 70 Cuda  (Read 1719 times)
Offline HP_Cuda
  • Mopar or No Car!
« on: August 31, 2012 - 01:24:01 PM »
I have a dumb question because I believe I already know the answer but does the lower flat piece of the front window trim get a gasket before mating with the body? I know it leverages a couple of bolts from the windshield wiper mechanism.
If anyone has a pic of the lower trim piece with the hood up that would be awesome!
Thanks,
Bryan
Re: Front window trim question 70 Cuda
« Reply #1 on: August 31, 2012 - 02:55:54 PM »
No gasket.  It uses two wiper bolts like you said.  Then the factory put a few blobs of sealer under it to hold it tight on the top side.  The corner pieces need some strip caulk around the attaching screws so you don't get a leak.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: August 31, 2012 - 03:32:45 PM »
Perfect! Now I need to know if the corner pieces are bolted to the car with machine screws?
I see no holes so I guess I'll have to make them...
Thanks a ton!
Bryan
« Reply #3 on: August 31, 2012 - 03:43:41 PM »
Mine are held on with chrome philips head screws.  They have a built-in washer on them.  There are slots where the screws attach...it isn't just a small hole.  That's why you need some strip caulk around the screw.  Water will leak in through the slot if it isn't sealed up.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: August 31, 2012 - 03:58:05 PM »
So its screw and bolt thru the firewall?
« Reply #5 on: August 31, 2012 - 04:09:44 PM »
The corner pieces are just held on with a screw into the cowl.  It doesn't screw into a hole...it screws into a slot.  Just like how the inside rear window trim screws are thread into slotts...not holes.
« Last Edit: August 31, 2012 - 04:11:57 PM by burdar »
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: August 31, 2012 - 05:58:39 PM »
As you can see from the pic I don't see any slots in this area to put a screw through. Hmmm it's a new firewall so it may not have them????
« Reply #7 on: August 31, 2012 - 06:43:40 PM »
Originally, there would have been a slot dirrectly under the trim hole.  The slot allows for some production tolerance stack-up.  If the cowl is new then it could be missing the slot.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: August 31, 2012 - 06:46:28 PM »
Hmm well unless I want to remove the front fender and drill a slot I'm sh*t out of luck.
Any ideas?
« Reply #9 on: August 31, 2012 - 07:56:43 PM »
Stick a pick through the trim hole when it's in the correct location and mark the spot to drill.  It looks like you have plenty of room.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: August 31, 2012 - 11:08:18 PM »
To get a straight up and down hole it will br close to the fender but doable.
 :horse:
Thanks for all the help!
Bryan
