Yup, Major redesign on the tunnel and cross member if you plan on using the factory torsion bars
Just out of curiosity, how did you decide on a tail shaft height?
If you compare a T56 to a 833. The input shaft will obviously be at the same horizontal plane.
But isn't the output shaft lower on a T56 than an 833 (keeping the input shaft level)? If This is correct then mounting the T56 tailshaft at the same height as a 833 would cause it to angle up changing drive shaft angles?
Correct me if I'm wrong, maybe I'm over thinking this.
I have both trans and will get measurements when I can.
