I believe so the crank & rods will be stronger & the piston weight lighter so nothing is working as hard , go easy with the boost & it will make serious power .
I built mild 440 a few years back stock block heads & crank , ported the heads , installed a good cam , dropped the compression with pistons , under drove the blower making 4-5 psi if that , good headers exhaust trans , converter & suspension & in a lightened 71 GTX around 3600 lbs race weight it ran 10.4 /133mph on a mild tune , we were going to increase boost & tune some more but the goal was low 10s , we hit it right out of the box !!
