Author Topic: non rally tach  (Read 4007 times)
Offline brotow
  • There really is a Challenger in the backround
non rally tach
« on: September 03, 2012 - 03:50:35 PM »
Does anyone know of a tach that would fit the clock pod in a non rally dash.  Othe than the mopar tach for non rally gauges(BIG bucks).  The clock delete "bezel" measures about 2 3/4 inches in diameter.
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline edl94
  • She Cuda
Re: non rally tach
« Reply #1 on: September 03, 2012 - 06:30:59 PM »
Offline edl94
  • She Cuda
Re: non rally tach
« Reply #2 on: September 03, 2012 - 06:54:18 PM »
Here it is installed.
Offline TinCuda
    • 'Cuda
Re: non rally tach
« Reply #3 on: September 03, 2012 - 07:43:38 PM »
I have one of those too.  I know it is a little pricy, but you will love it.
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
Offline TinCuda
    • 'Cuda
Re: non rally tach
« Reply #4 on: September 03, 2012 - 08:07:27 PM »
Here is a picture of mine...
Also if you get it from Year One, it will cost a little more but they have a "No questions asked" return policy.
https://www.yearone.com/Product/DisplayProduct/208704
This is just my humble opinion, but if you have a non-rallye dash E-body, with an auto transmission like I do, This is the only Tachometer to use.  Most people that see it think it was factory installed.
« Last Edit: September 03, 2012 - 08:21:29 PM by TinCuda »
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
Offline Fern
Re: non rally tach
« Reply #5 on: September 04, 2012 - 05:07:00 PM »
Would it be possible to install the tach to where the fuel gauge is and install the fuel gauge to the far right.
Offline TinCuda
    • 'Cuda
Re: non rally tach
« Reply #6 on: September 04, 2012 - 05:58:49 PM »
Because of the way the actual frame work of the gauge cluster is cast, the tach will only fit in the far right position.
I would love to have shifted everything one space to the right and put the tach next to the speedometer.
Sorry.
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
Offline TinCuda
    • 'Cuda
Re: non rally tach
« Reply #7 on: September 04, 2012 - 06:08:40 PM »
I soppose anything is possible.  You can see in this picture of my spare cluster that the place for the clock is the only location that is just a hole.
You could build a backing frame for the fuel gauge and cut out the back where the fuel gauge was for the tach.
Kind of a "work vs. reward" question.
« Last Edit: September 04, 2012 - 06:16:29 PM by TinCuda »
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
Offline HP_Cuda
  • Mopar or No Car!
Re: non rally tach
« Reply #8 on: September 04, 2012 - 07:33:15 PM »
OMG that rocks!!! Looks like I'll be doing that!
Nice and clean look without mounting one on the column!
Offline tuff340GranCoupe
Re: non rally tach
« Reply #9 on: September 09, 2012 - 05:59:08 PM »
I would prefer the tach be in the place where the fuel gauge is. Somebody out there with alot of time on his hands could modify one of these housings & shift them over. I don't know if this could be welded up either but hey anything is possible. I guess its anyone choice if they place it in the clock space or modify their dash housing & go from there. Either way, I like the clock better, but that tach is way-cool too!
Offline Road_Runner
Re: non rally tach
« Reply #10 on: September 12, 2012 - 01:56:45 PM »
I've always thought the standard gauge arrangement was odd if not backwards.  On my Roadrunner's Rallye dash the gas gauge is on the far right instead of right beside the speedometer.  I've looked at those in dash tachs, but I'm probably going to go with a period correct tach mounted in front of the blank gauge on far right.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline TinCuda
    • 'Cuda
Re: non rally tach
« Reply #11 on: September 12, 2012 - 05:57:49 PM »
Later, Jim
Yeah, that's the setup that I used to have.  It looks and works just fine.  I know that the ideal place for the tach is right next to the speedometer, but in front of the clock position works too.  It is centered on the car and I think you can keep a better eye on the road infront of you when you have it hammered.  It is also outside of the steering wheel so you don't have to keep looking through the steering wheel to try to see it.
I wanted my dash to look more original so this tach was a no-brainer.  I was already used to looking in that location for tach info, and it looks as good a factory.
This is what my dash looked like in high school.
« Last Edit: September 12, 2012 - 05:59:54 PM by TinCuda »
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
Offline Road_Runner
Re: non rally tach
« Reply #12 on: September 13, 2012 - 09:27:52 PM »
That's exactly where I'm thinking about putting my tach.  It really depends if I go for a seriously original look or just a period correct look like I'm doing on the Roadrunner.  I've got an old 70's Mopar tach that should look like it belongs.  Its still a shame its so difficult to move the gauges around in the standard dash, I'd definitely like the tach next to the speedometer.
Later, Jim
