Author Topic: Can't get key out of ignition  (Read 925 times)
Offline BP23G0B
« on: September 03, 2012 - 04:37:23 PM »
Hi guys,
I can't get my ignition key out of the column.  It's stuck between on and off.  I can fire the engine and turn it off but can't get the key to turn completely counter clockwise to get it out.  I fiddled with the gear selector and no matter what gear it's in, the key won't release.  P-R-N-D seem to be lined up right.  Does anyone have a detailed diagram of the inside of the column?
'70 Barracuda Gran Coupe
'14 Ram 1500 Express Black Edition
Offline Sleepychallenger
Re: Can't get key out of ignition
« Reply #1 on: September 03, 2012 - 04:43:50 PM »
Try grabbing the collar and moving it a bit or the park lever under the hood on the Column and move it a bit.
« Reply #2 on: September 03, 2012 - 08:55:26 PM »
must be a 70 , only year they had linkage from the trans to the column to rtate the column so the key would remove , the used a spring 71 up
« Reply #3 on: September 03, 2012 - 09:01:57 PM »
Thanks chryco. I didnt know that was a 70 only thing
