Author Topic: 72+ rallye guages 7k tach switch to 8k repop tach  (Read 929 times)
Offline Haddixj
« on: September 03, 2012 - 08:59:23 PM »
Is it possible if I bought the 72 and later to switch the tach with the aftermarket repop 8k tach? Thanks
Offline EddieE
Re: 72+ rallye guages 7k tach switch to 8k repop tach
« Reply #1 on: September 03, 2012 - 11:19:57 PM »
Yes, call Gentry at Auto Instruments.  I have a 74 with 7K tach in rallye gauge cluster and he told me that I could choose a VDO 7 or 8K when he redid all of my gauges.  I kept the 7K as I have my rev limiter set at 5500 anyway.
Offline Haddixj
« Reply #2 on: September 04, 2012 - 01:13:06 AM »
Okay is the vdo a factory looking tach? I am looking a keeping the guages all factory but just buying a new 8k tach and putting it in a 72+ cluster
Offline EddieE
« Reply #3 on: September 05, 2012 - 09:47:38 PM »
Haddixj, this tach will make all your wildest dreams come true (Napolian Dynamite).  First, you tell them whether you want a 7,000 or 8,000 RPM tach.  Then you get all of your gauge faces redone, your gauges recalibrated, and your clock "quartzed".  The VDO reference is to the mechanics/electronics of the tach, not the face.  They set it based on your 7,000 or 8,000 preference.
I just installed an MSD 6AL because I have a 4-speed car and I wanted beter electronic ignition + a rev limiter.  I mention this because the VDO tach is MUCH more accurate with the MSD.  Also, when you turn the ignition key, the tach will jump up to your rev limit to confirm the RPM at which the limiter kicks in.
