Author Topic: Best way to go engine/trans  (Read 734 times)
Offline glovemeister
« on: September 04, 2012 - 03:11:05 AM »
I've got a 71 Challenger R/T that was originally a 383 HO, with I believe a 727.
From my understanding the stock trans needs a rebuild.
I originally thought the car was a 340 and finding such a motor is really hard. My plan was to go with a 318.  Since I verified it was a 383 I know those are easier to find. I would like to find a correct year or earlier 383 to put in there.
So my question is would a 318 swap be able to use the same trans I have? I assume motor mounts have to be changed?  Is there any difference between driveshafts of big blocks and small blocks?
Thanks,
1971 Challenger RT
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Best way to go engine/trans
« Reply #1 on: September 04, 2012 - 06:28:49 AM »
If your transmission in your car now is for the 383, then no it will not bolt up to a 318. The big blocks and small blocks have different bolt patterns.
1996 Dodge Viper GTS Coupe
Offline Tonker1
« Reply #2 on: September 04, 2012 - 07:26:22 AM »
So the car was originally a 383, it got changed to a 318 and now you want to change it back?
If your changing to a 383 from a 318:
You can use the 727 trans, but you would have to change to a big block bell housing to make the bolt holes line up.
Yes, the mounts have to changed.
