Author Topic: IGN SWITCH.  (Read 1108 times)
Offline 383DART
IGN SWITCH.
« on: September 04, 2012 - 06:59:45 PM »
 :working:HI guy's. have a 70 barracuda ign switch will not turn off all the way.auto with console shift.switch turns off engine,switch/key stops just before on the off position so you can't remove the key.car does start in park.any input.thank's.
Re: IGN SWITCH.
« Reply #1 on: September 04, 2012 - 07:14:31 PM »
Thankfully my car didn't have this, but is there a "sleeve" that you have to rotate to get the key out?
Offline HP_Cuda
  • Mopar or No Car!
Re: IGN SWITCH.
« Reply #2 on: September 04, 2012 - 07:26:43 PM »
Yep! Reach down the column and grab ahold and turn to the right (clockwise) that will unlock the key and you can take it out.
Don't ask me how I know..... :bricks1:
Offline BP23G0B
Re: IGN SWITCH.
« Reply #3 on: September 08, 2012 - 03:30:20 PM »
That was it.  I got the key out after turning it counter clockwise. 18 years and I hadn't noticed it rotates.   :dunno:
What's the purpose of this sleeve?  There is an allen key in it.  I tried to tighten it down but it doesn't move.  Is the sleeve supposed to flop around like that?
'70 Barracuda Gran Coupe
'14 Ram 1500 Express Black Edition
Re: IGN SWITCH.
« Reply #4 on: September 08, 2012 - 04:06:22 PM »
in 70 only there was a rod from the column to the trans so the key could not be removed until it was in Park [Auto] or reverse [4spd] , I have virtually never seen a 4 spd with the linkage in place , who wants to put it into reverse every single time? 71 up uses a a lever on the column with a spring which they still use today , I still have no clue why you have to push a button to remove the key  :clueless:
