Hi All,
I've been battling intermittent cooling issues with my '72 Challenger for awhile now and I am running out of ideas. I have a 440 engine in the car and I've replaced the obvious stuff like the water pump, radiator cap, thermostat, and hoses. I've also disconnected the heater core hoses, as they were leaking. I thought the leaky heater core was the last bug to work out, but I was wrong after this weekend's drive!
When I last took the car out, the temp was steady, but started to creep up to 220 and stay there, after driving around town for 20 minutes or so. I made it home, opened the hood and heard bubbling in the radiator. The radiator did not leak oroverflow, and after cooling down, I checked the fluid level and it is completely full to the top. I have an infrared heat sensor, so I'm 99% sure that my aftermarket temp gauge is accurate.
The only part left to replace is my radiator itself and I am wondering if it is undersized for the big block engine. It meausres 28" wide by 2" deep. It also has the fan shroud and there is no A/C on the car. I don't know how many rows the radiator has. It seems big enough and looks fairly new outside and inside (i.e. no obvious rust). I didn't install it, so I don't know what type it is.
I'd appreciate your advice on what else I should do or consider. I'm thinking about swapping out the radiator for an aluminum one, but I'm not sure if that will fix the problem. I also don't know what size radiator or how many "rows" a radiator should have for a big block engine.
Any thoughts?
