Author Topic: keep blowing fuse #8  (Read 3282 times)
Offline NCtrueconservative
« on: September 05, 2012 - 07:25:13 PM »
Hadn't been on in a while. Last time I drove the car (73 rallye challenger), I kept blowing fuse number 8 (one in the lowest right corner on the fuse block). At first it seemed to blow when I floored it, and I would lose my tach, signal lights, etc.  But then, it got to where as soon as I put a new one in, and started the car, it would blow.  I crawled under the dash and couldn't see any open wires that could be shorting out or anything. Any ideas??
1973 Dodge Challenger Rallye (pictured), 340, Slap Stick
1998 Dodge Ram, 5.2, Black, tinted windows, dual exhaust, blackout headlights, tailights
Offline Jamiez
  • Retro
Re: keep blowing fuse #8
« Reply #1 on: September 05, 2012 - 07:30:08 PM »
When mine was blowing it was the wire from the transmission for the reverse light grounding against the brake booster.
Unfortunately fuse 8 runs a lot of small bits which go hot with the key (radio, turn signals, reverse light, clock, etc) so it will probably be a real pain to track down
Offline TinCuda
    • 'Cuda
« Reply #2 on: September 05, 2012 - 07:36:10 PM »
I am having the same problem.   I replaced my turn signal flasher thinking it might be blowing the fuse due to some resistance or something.   No help.
Replacing my fuse will fix my signal problem for a short time.   Everything works fine, start the car, drive it around the block and by the time I get home, the fuse is blown again.
No loose wires under the dash and no radio installed.
 :popcorn:
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #3 on: September 05, 2012 - 08:24:01 PM »
Mine just blew this past weekend. I haven't had a chance to really dig in. I did check turn signal wires & they looked good from the bulb sockets. Guess I've got some more digging to do!  :bricks1:
        Matt B.
Matt
Offline ShelbyDogg
« Reply #4 on: September 09, 2012 - 01:35:18 AM »
Put a bulb across the fuse terminals. The light will come on bright if the short is there, Start unplugging sections of harness till the bulb goes out, then start following those wires till you find the short.  On my 70, the lower right fuse goes to my running lights, dash lights and cig lighter.
Rob
« Reply #5 on: September 10, 2012 - 01:00:21 PM »
According to a '74 service manual, cavity # 8 supplies the: Backup Lamps, Turn Signal Circuit, Radio, Reverse Gear Indicator lamp. It should be the same for '73.  :2thumbs:
        Matt B.
Matt
Offline ChallengerHK
« Reply #6 on: September 10, 2012 - 06:30:39 PM »
                                                  Matt B.
Of that list, I'd be looking at the hot lead for the radio first to see if it's shorting.
- Han Solo, Star Wars
