Author Topic: Drum to power disc brake conversion  (Read 3700 times)
Offline 440-6 Challenger
« on: September 05, 2012 - 10:44:30 PM »
Hi.....  I'm closing the purchase on a 1970 Challenger RT with a 440-6 (originally a 383 car). It's all original and to would like to keep it close to original  During a check out I discovered to brake system is shot and needs a complete rebuild. In fact the front drums must be replaced (expensive).  So I'm at a cross road.....  Rebuild or convert?  I'm sure many of you have been down this road. I'm looking for any opinions, recommendation and words of wisdom.
If there is a thread on this subject, please point me
Thx in advance
Robin
Re: Drum to power disc brake conversion
« Reply #1 on: September 05, 2012 - 10:50:56 PM »
no brainer , toss the drums in the corner if someone wants a trailer queen & put on discs , use the FMJ splindle Volare Mirada 5th ave Caravelle etc & swap to the Cordoba 11.75" front disc brakes
« Reply #2 on: September 06, 2012 - 08:50:42 PM »
What about all these conversion kits from Summit, Winwood, SSBC,In Line Tube, Stainless brakes and others.  Most don't mention a spindle replacement.
« Reply #3 on: September 06, 2012 - 08:58:21 PM »
Probably more expensive , they use the drum spindle which saves some hassle  Bear is another option , Brad did a Viper conversion , 17 " wheels will allow bigger brakes as well . Also check out Scarebird , they make adapters & use common parts
« Reply #4 on: September 06, 2012 - 09:50:15 PM »
If you neeed spindles and the "Doba" pin caliper brackets I have a pair for sale?
http://www.cuda-challenger.com/cc/index.php?topic=84268.0
« Reply #5 on: September 08, 2012 - 11:58:40 PM »
 :popcorn:
« Reply #6 on: September 16, 2012 - 07:06:26 PM »
Looks like I may go with a conversion kit from Master Power Brake.  I keep running into unknowns like 15" wheel requirements and vacuum pressure limits on my 440.  Looks like I have to go with manual front disc conversion.
I still half way leaning towards simply a drum brake rebuild as an interim till i get a better handle on the right way to make the upgrade and what iwamt yo do.  I found stock 11" front drums for $100 ea.   I was really surprised this wasn't std stock upgrade process given the popularity of this car
http://www.mpbrakes.com/products/list.cfm?make=dodge&model=challenger&year=1970&product=93
Hey.....  But learning about the Challenger part of the fun of owning a classic muscle car.
Keep you posted on the evolution.
Ps. What's a stock 1970 Challenger 383 RT with a factory 440-6pack conversion worth?  Solid. No rust.
