Author Topic: Removing and installing the glass in the doors and quarter window.  (Read 14219 times)
Offline TROUBLE987
« on: September 06, 2012 - 09:06:56 PM »
There has got to be a easier way..I spent a hour getting one door glass out..can someone please give me some help..I have worked on cars all my life but this is crazy..is there any steps to it?I can't imagine putting the new glass in..thx
Re: Removing and installing the glass in the doors and quarter window.
« Reply #1 on: September 06, 2012 - 09:39:39 PM »
Did you take the outside edge whisker off first? You need to do that.
The holes on the glass are there so that as you wind it up and down, you can access bolt assembly areas.
Certain hardware is used in certain places.
For example: the allen bolts are the top of the guides to be mounted onto the inner door.
Use a allen cut off put into a socket on an extension.
Offline Sleepychallenger
« Reply #2 on: September 06, 2012 - 10:02:00 PM »
I'm glad I'm not the only one who has problems with this. I'm gonna need lots of help getting it back together
« Reply #3 on: September 06, 2012 - 10:52:08 PM »
I just installed the side glass on my Challenger.  The 1/4 glass is a piece of cake.  The door glass sucks.  After I had it in, the guy that did the bodywork on the car gave me a tip.  He said he installs the glass in the door BEFORE the window fuzzies are installed.  If the lower rubber bumper is removed, the glass will slide down lower so you can install the door fuzzy.  Trying to get the glass in with the fuzzy installed was the biggest issue I had.
The front track needs to be removed with the glass also.
Offline TROUBLE987
« Reply #4 on: September 07, 2012 - 07:45:02 AM »
Well thx for the help guys. Im going to try this info on the passenger side
Offline TROUBLE987
« Reply #5 on: September 07, 2012 - 08:58:26 PM »
Guys this was a ton of help thank you very much..if you lived closer I would buy you a beer..:)
« Reply #6 on: September 07, 2012 - 09:06:40 PM »
Copy, Save, & Print...
« Last Edit: September 07, 2012 - 09:09:12 PM by Topcat »
« Reply #7 on: September 07, 2012 - 09:10:18 PM »
PM me your e-mail if you want these sent as attachments to your e-mail.
« Reply #8 on: September 07, 2012 - 09:20:32 PM »
One more...
So many files.  :faint:
« Reply #9 on: September 07, 2012 - 09:25:10 PM »
Differences between reprocuction whisker mounting vs. OEM whisker mounting.
Been battling with this myself. The chrome trim on them is supposed to ride just barely on the edge.
Whisker reproductions are way off, even on the OEM side positioning.
Offline TROUBLE987
« Reply #10 on: September 07, 2012 - 09:47:57 PM »
Oh yeah..thx for the hook up..printed and stored..might be atleast a year before I look at it again..have got a little more tearing down then it's off to the blaster..
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: September 08, 2012 - 12:20:38 AM »
Thanks Mike I printed them all out!
 :working:
« Reply #12 on: September 08, 2012 - 11:13:51 PM »
When you have all the quarter glasses done, I recommend riveting the whiskers onto the quarters.
The clips on the outer whiskers totally suck on how how they align against the body.
Thats what I did today and they hug up much nicer then if I just tried to clip them in.
Offline TROUBLE987
« Reply #13 on: October 07, 2012 - 10:49:02 PM »
Thanks for the heads up
« Reply #14 on: October 08, 2012 - 12:34:38 AM »
An idea for those of you that still can't get the side glass windows figured out:
Save the file, Convert it to a pdf. take it to a Kinkos on a travel drive, and have them print it onto a chart plotter printer.
Now you will have a blown up drawing to see everything really up close.
Parts questions:  Can be Asked here.
R/T Restorations and Jim's Auto parts shows good descriptions.
Look at both websites and compare to understand.
