Author Topic: cuda ignition probllem  (Read 1310 times)
Offline Shane_OBrien14
« on: September 09, 2012 - 02:41:18 PM »
went to go drive the car and ran fine, got almost a quarter mile down the street when she stalled out. only started when i had the pedal to the floor and barely moved. put a old mustang ignition coil on ran fine for a little now wont start back up. any ideas?? did i mess up the timing/ foul the plugs?
Re: cuda ignition probllem
« Reply #1 on: September 09, 2012 - 04:39:14 PM »
We need a little history of your car.
Did it run fine up until now, or has it sat for any length of time?
If it only started when you floored the gas pedal, this isn't an electrical problem.
If it has been sitting a while, I would say a clogged fuel filter, or crud in the carburetor. Maybe even stale gas.   :dunno:
« Reply #2 on: September 09, 2012 - 05:48:18 PM »
the car has sat for about ten years, i cleaned the carb, and cleaned the fuel filter. also put 5 gallons of premium fuel in.
Offline 72cudamaan
« Reply #3 on: September 09, 2012 - 06:54:56 PM »
Are you sure the choke isn't closed?
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Jamiez
  • Retro
« Reply #4 on: September 09, 2012 - 07:04:21 PM »
Was the tank sitting empty for 10 years?  They tend to corrode up when they sit empty a long time.  I'd check the filter again and see if it's not all clogged with rust/scale and other nastiness it might have picked up from the tank.
If it's cranking and it has fuel, next I'd look at spark, particularly weak spark.  You didn't say what year you had so I'm not sure if you have electronic ignition or the older point style.  Might be worth pulling the distributor cap and making sure everything is clean/gapped right/etc.
« Reply #5 on: September 10, 2012 - 04:20:23 PM »
its a 74 318. i drove it and it just cuts out after like 20 minutes and doesnt start again.
Offline Jamiez
  • Retro
« Reply #6 on: September 10, 2012 - 06:17:06 PM »
Most of the time when people have that problem, it's a bad coil.
