Author Topic: 440 hesitates off idle  (Read 7878 times)
Offline WVUFELLA
  • (OO/---------\OO) closest i could for a 72
« on: September 10, 2012 - 04:48:16 PM »
440 hesitates off idle..jus went up to a 31 nozzle and put pink pump  on....can't figure out hesitation
I put a video on tube called mopar 440 hesitates off idle any ideas???
Mopar 440 hesitates off idle
« Last Edit: September 11, 2012 - 08:29:44 AM by WVUFELLA »
Re: 440 hesitates off idle
« Reply #1 on: September 10, 2012 - 08:57:09 PM »
Is there any play in the accelerator linkage , is the float level correct ?
a larger squirter will get a bit more fuel there immediatly , the bleed for the jetting may need to be downsized or restricted with a piece of wire
Offline WVUFELLA
« Reply #2 on: September 10, 2012 - 09:11:41 PM »
As soon as I move the accelerator the pump arm starts to move...the people at Holley said get bigger nozzles but I have read on here that for my motor setup I shouldn't need anthony bigger than a 31..as for how to restrict jets.....I have no idea what your talking about....but willing to learn
« Reply #3 on: September 10, 2012 - 09:56:03 PM »
never say never ,  a larger squirter allows more fuel in fast but the duration of the squirt is lessened which can cause it to stumble as the secondary opens & the volume is the same either way .
 If you look down the throat of the carb you will see 8 small brass inserts 2 by each booster  , on Proforms , Quickfuel & Holley HP these can be unthreaded & changed , on most carbs they cannot , the outer bleeds are for the idle mix , the inner are for the jet circuit  often with low vacuum the engine will not run well , inserting a thin piece of wire such as .028 mig welding wire into the jet circuit bleeds can make a big difference in the way a car runs , & usually  form the wire into a U shape & trap the wire behind the squirter so  it will not fall out .
Offline ek3
« Reply #4 on: September 10, 2012 - 11:15:04 PM »
have you looked into the carb to see if there is actually a good stream of fuel ? i see the pump move but does it shoot fuel without delay ? verify that first ..   it is obviously a timing issue [fuel shot timing] slower throttle smoother transition. faster throttle it goes lean! be sure the pump is working properly. it my have a restriction somewhere.  also , there may be a vaccum sorce leak, causing poor carb signal.check all vaccum sorce /ports ect.  if all checks out , then a faster cam and or bigger set of squirters .
Offline WVUFELLA
« Reply #5 on: September 11, 2012 - 08:31:12 AM »
I will try to post a video of that tongiht.... I think i am gettin a good shot ... but another set of eyes is always good for reassurance...
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #6 on: September 11, 2012 - 09:44:36 AM »
Watch out for back fires!!!
Offline WVUFELLA
« Reply #7 on: September 11, 2012 - 08:21:27 PM »
So I videoed the Carb taking fuel..doesn't look like a problem to me....you tube video is called Carb feeding fuel
Offline Jamiez
  • Retro
« Reply #8 on: September 11, 2012 - 08:26:00 PM »
Embedded:
Carb feeding fuel
« Last Edit: September 11, 2012 - 08:27:40 PM by Jamiez »
« Reply #9 on: September 11, 2012 - 08:41:31 PM »
looks like lots of fuel to me are the plugs going black
Offline ek3
« Reply #10 on: September 11, 2012 - 10:18:46 PM »
you can check pumpshot without engine running :thumbsup:
« Reply #11 on: September 11, 2012 - 10:38:01 PM »
Geeze, I'll remember for next time!  :pullinghair:  :roflsmiley:
Offline ek3
« Reply #12 on: September 11, 2012 - 11:09:02 PM »
ok. best i can see the pump is working good, ''mabe a little late''. if you close the choke  about 2/3 shut, then open the throttle and it helps, you know that there is not enough booster signal to pull fuel from the boosters! you can then add a faster cam and or larger squirter to '' fill in '' the gap. be sure to install the cam in the correct positions / holes and be sure to adjust the accel. pump to .015 ''clearance @ full throttle pos.   what vaccum does it pull on the guage ? i would also check the ignition timing , ive seen many a lazy engine wake up with that one!!
« Last Edit: September 11, 2012 - 11:18:42 PM by buddy whittington »
Offline WVUFELLA
« Reply #13 on: September 12, 2012 - 06:55:44 AM »
You are correct but it is hard to hear if and when the engine hesitates/backfires/ when the engine is off :smilielol: :smilielol: :smilielol: Thanks jamiez... when i upload videos from my phone i dont know how to cut and paste a link onto the forum ... i have to wait till i get on a puter....Will try to check plugs tonight.... black is to rich and _______ is to lean?
« Last Edit: September 12, 2012 - 07:11:03 AM by WVUFELLA »
« Reply #14 on: September 12, 2012 - 07:33:01 AM »
white or grey is lean , it should be light tan
