well i tried a 33 then a 37 and still the same problem...so i called holley and they wanted me to check the power valve... Street avenger comes with standard 6.5... so i chekc the vacuum last night it was at 11 inches with car in gear at idle... whihc in holley terms equates to a 5.5 power valvwe ... my question is doesone size power valve make that big of a difference? also what happnened to the bolt on and go with two adjustments.... idle screws, floats, power valve, nozzles, pump cam , pump lever arm, idle screw..... they must have meant you have to adjust all of those items twice? anyways still have the problem... yall recommend changing out power valve.... ps i have the silver spring in the vacuum diaphragm
