My first recomendation is Smith Bros in Bend Oregon , talk to Pierre , But you need to measure the length you need , so you need a pushrod checking tool , you want approx 2 threads on the adjuster showing below the rocker arm & the lifter has to be on the base circle of the lobe to measure correctly .
The second choice is comp cams , they have a variety of different lenghts available but none of them are right in my experience , too long or short .
The lifter used will alter the length of the rod needed so there is no std length that just fits .
