Author Topic: '78 Dodge D100 Pro-street with EFI and Over Drive  (Read 1204 times)
Offline Dragula
« on: September 11, 2012 - 12:18:11 PM »
'78 Dodge D100 360 Pro Street with ladder bars, 4.56 gears, Over Drive (drops 700rpm at the flip of a switch), & posi, drive shaft loop. Strong fresh 360 with .484 purple cam, solid motor mounts, EZ-efi injection. Custom in bed hidden fuel system with in tank A1000 pump and AN10 lines thru out, switchable bypass regulator for efi/carb, proform electric water pump, line lock, 3" wheel studs, legal battery hold downs and on/off switch, 14v mini alternator, custom valve covers, custom curved distributer, under drive alum pulley. SMR custom built A500 OD trans .76 ratio with custom vavle body and 3000rpm stall lockup convertor and deep pan. Custom 3" exhaust that works well for bracket racing and street driving, but also have the quieter 2.5" if wanted. Sounds awesome with the 3". This truck is super reliable, and I drove it to work this summer every chance I got. Runs low 8's in the 1/8th, but I have not run it since installing the new custom recurved distributor. It pulls a lot harder now. Should go high 7's in the 1/8th. Custom paint and interior, fiberglass bumper, custom sheet metal rear bumper, custom headlights, fully street legal and a blast to drive. Working wipers. Only thing it needs are a good set of gauges in the dash.
NEW LOWER, LOWER PRICE....Gotta go!
$10K W/O EFI or best offer....
« Last Edit: September 11, 2012 - 12:21:32 PM by Dragula »
