Author Topic: 7290 yoke????  (Read 1393 times)
Offline burnoutking-1
7290 yoke????
« on: September 11, 2012 - 09:34:27 PM »
So I went to put the driveshaft out of my '74 chally with 489 case 8 3/4 into my '73 chally with 489 case 8 3/4 and my son sais "something doesn't look right"...turns out it has a  7290 yoke.
So just wondering if this isn't just a strength upgrade done by someone(previous owner was building a drag car with it), then is it possible this rear came out of a big block car or something more special than my 360 and 340 cars.
The '74 had a 2.76 geared open carrier... and the '73 has a 3.23 geared sure-grip.
Re: 7290 yoke????
« Reply #1 on: September 11, 2012 - 09:54:26 PM »
Precision has a conversion U joint 7260 one way & 7290 the other to solve that situation
Re: 7290 yoke????
« Reply #2 on: September 13, 2012 - 06:49:07 PM »
Actually it can't be a 7290, because the u-joint for that is a good inch to narrow still.
All it sais on the yoke is spicer...so is that a 1350  u-joint??
Re: 7290 yoke????
« Reply #3 on: September 13, 2012 - 09:12:35 PM »
Okay, got it figured. I was measuring full u-joint width, not clip to clip.  Also a little confusing, because it turns out the other car was reversed. It had a 7260 diff yoke and 7290 driveshaft end.
I guess that's a good thing ...now I have a full 7290 setup.
