Author Topic: Rear Seat Removal  (Read 8417 times)
Offline Road_Runner
Rear Seat Removal
« on: September 12, 2012 - 01:52:26 PM »
This is kind of embarrassing, but I can't get the back seat in the 73 Barracuda to unhook from the floorpan!  I've done this more times than I can count with other cars but for some reason I can't seem to push the seat bottom far enough rearward to allow it to unhook.  I've use all my weight, strength, screwdrivers, pieces of wood, you name it and nothing has worked.  If any of you have had this problem how did you end up getting the seat out?  I've been trying to replace the rear wiring harness for a couple of weeks, but the seat has me stumped.
Thanks in advance, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Re: Rear Seat Removal
« Reply #1 on: September 12, 2012 - 02:11:31 PM »
Well, the steps I go through would be 1/ tug the seat bottom towards the front of the car. 2/ push the front edge down hard. 3/ push to the rear and lift.
If that doesn't work, something is under the seat preventing you from pushing it down? Or the tang on the seat frame is bent?
« Reply #2 on: September 12, 2012 - 03:57:56 PM »
I seem to remember the push down, slide forward method working for me.
You definitely don't pull up.   :grinno:
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: September 13, 2012 - 10:35:36 AM »
Getting it out is a trick. . . . But getting it back in?   :pullinghair:
« Reply #4 on: September 13, 2012 - 11:04:17 AM »
I thought you pushed down then back , then lifted? I just pulled mine out last week to run some wires .
I just ran out and checked.... yep push down and back then lift.
Offline BIGSHCLUNK
« Reply #5 on: September 13, 2012 - 11:54:47 AM »
I had the same problem!  :banghead:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #6 on: September 13, 2012 - 12:14:50 PM »
What's the rear seat bracket(s) look like? Any pics?
« Reply #7 on: September 13, 2012 - 01:19:50 PM »
I just happen to have mine out still, sorry about the crappy cell phone picture but you get the idea.
« Reply #8 on: September 13, 2012 - 05:21:26 PM »
Same idea as a 67-69 Camaro for holding the bottom rear seat in place.
« Reply #9 on: September 13, 2012 - 05:46:28 PM »
I just slide it in , and push down, ?  Lift up to see if it catches? For me the hardest part is keeping the darn seat belts from sliding back under the seat.  ;D
« Reply #10 on: September 13, 2012 - 06:46:29 PM »
You sometimes have to grunt and get the right facial expression to get the rear seat out!
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #11 on: September 13, 2012 - 08:27:41 PM »
you should try and feel around were it hooks to see if something has lodged in behind the hook area and not letting it push back far enough to release
72rtchallenger
what happens in the garage
stays in the garage
Offline Road_Runner
« Reply #12 on: September 13, 2012 - 09:21:44 PM »
Thanks for the feedback, but I pulled the car out in the driveway so I could open the doors wide and finally got it out!  The passenger side unhooked when I could get at it better, but the drivers side still did not want to come out no matter how hard I pushed or pulled.  Its definitely a push down & back, then up & forward process because of the shape of the hook holding it in.  This isn't nearly as hard in the Roadrunner, must be the smaller seat bottom making it have less room to move.  How I finally got it unhooked was I took my BFH (Big F'n Hammer) and my largest blade screwdriver and whacked at the front of the wire loop until I could get it back far enough to push it the rest of the way.  I'm not sure if the rear seat which is recovered is thicker than original making it bind sooner when pushed back or if the wire loop that catches in the floorpan hook was bent too far forward, but there was no way it was going to unhook without some serious hammering.  If its even half this much fun going back in I'm not going to even try it until I'm all done doing everything I need to do with it out!
Later, Jim
