Okay, so I guess I have SS springs already. 3600 lb. Offset hangers are also 2" longer than stock.
That explains why the car sits a almost 2" higher on the passenger side. Seems a little much though, and not really to my liking. I guess I could either move the front spring eye up a hole, or get a spacer block.
Whoever did the rear messed up also. They rewelded the spring pads so the diff is up a few degrees and the pinion snubber is already touching the floor. Just sorta locked the rearend in there.
Driverside stance is pretty good. fender sits just lower than the tire, but passenger has a good 1 1/2" of daylight.
Does this sound right for Mopar SS springs??
