Author Topic: Torque Converter ????  (Read 2042 times)
Offline Bart
« on: September 12, 2012 - 04:50:32 PM »
Ok guys need help with torque converters, I have a 383 with Indy heads, cam 284/296 and 507/510, 1.6 rockers, 780 Holley, RPM intake dual plane,  will be running 3.91 gears, 1970 Cuda,
451 tq at 4500 rpm
452hp at 5500 rpm
So my question is what stall do I need to run on the street and not build a lot of heat, will add cooler if needed.
Thanks & regards
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
Offline burnoutking-1
Re: Torque Converter ????
« Reply #1 on: September 12, 2012 - 05:14:42 PM »
I'd say around 3200
Offline Bart
« Reply #2 on: September 12, 2012 - 05:22:39 PM »
So i have been told
2500-3000
300-3500
and 4200 flash
I'm  :clueless:
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
« Reply #3 on: September 12, 2012 - 07:15:36 PM »
So you are running this on the street and not doing any Highway driving, right?
I'm thinking 3000 to 3500.   :2cents:
Offline Bart
« Reply #4 on: September 12, 2012 - 08:10:46 PM »
Maybe a few time to get to meets, so what if I went with 3:55 and not the 3:91's
thanks
Steve aka Bart
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
Offline 72cudamaan
« Reply #5 on: September 12, 2012 - 10:19:06 PM »
I'd say 2800-3200. Is your max rpm gonna be somewhere near 5500?
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Bart
« Reply #6 on: September 13, 2012 - 10:23:43 AM »
Going to chip it at 6000rpm.......
Regards
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
Offline MetalMilitiaSRT
« Reply #7 on: October 04, 2012 - 06:02:41 PM »
Sorry for the thread hijack here but how do I find the stall if I don't have a tach?
After all of the tuning and the parts that I have I am rather certain that I need a higher stall.
When in D, it idles so slow that everything shakes and it nearly dies. We played a lot with the carb and the timing, and its better, but still not quite there.
The cam (we found out when doing the head work) is a Mopar Performance Purple 282/484.
Other upgrades include a RPM manifold and a AED (holley) hp750. ( It is a 1967 440+.030, by the way)
My guy here that helped me do all this work suggests a 2600-2800 stall but admits to not being a transmission specialist.
Does that seem about right?
I wont be racing at all, just the occasional light-to-light runs.
73 Challenger
05 Crossfire SRT-6
06 Brutale 910s
09 V-Star
83 Civic (commuter...42mpg!)
Offline jhaag
« Reply #8 on: October 04, 2012 - 07:15:55 PM »
Do yourself a favor and contact the tech line at one of the convertor manufacturers. ATI, TCI, etc. They can give exactly what you need, based on all the available info. Your extensive engine info, and especially dyno info, will allow them to get it right the first time. Also most reputable manufacturers will tweek your convertor if you are not satisfied, for minimal expense.
love 70 Challengers
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #9 on: October 04, 2012 - 08:42:53 PM »
 :iagree: The folks at TCI seem to be pretty sharp. They treated me well and gave good solid advice. I fried the original torque convertor on my big block stroker motor (543). I was running it on the steet with a 2800 stall, 3:91 gears, 295/50/15 tires. It didn't last long. I have a little bigger motor than you but still a big block with my rev limiter set at 5600 rpm. I ended up with an approx 4000 rpm stall convertor (3800-4000) which works excellent now. When you call the tech line be preparred to give engine specs, tire size, rear end gearing and how you plan on using the vehicle. They will base their answer on what you tell them. Good luck!!
        Matt B.
Matt
Offline Bart
« Reply #10 on: October 05, 2012 - 05:17:09 PM »
I called Dynamic TC and he built me a TC, stall is about 3800-4000 also, but $$$$
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
