Author Topic: Rear Brake issue  (Read 1401 times)
Offline AARCUDADEN
Rear Brake issue
« on: September 13, 2012 - 01:45:34 AM »
My rear brakes on my AAR are draging, feels like an ancor tied to back. I'm ready to pull out what hair i have left out  :pullinghair: trying to figure this thing out. I've replaced rear wheel cylinders. Is it possible the rear brake hose is the problem? I don't want to keep throwing money at it trying to find the problem. If anyone can give me things to look for would be a big help right now  :wave:
Dennis,Ohio
Offline hooD
  • detroit iron
  • Motor City Made Muscle
Re: Rear Brake issue
« Reply #1 on: September 13, 2012 - 05:34:46 AM »
I'll be watching this thread.  My passenger rear drum gets super hot but the other side is ok.
Have you replaced any of your brake hardware...springs.....clips...brake adjuster star wheel?
« Last Edit: September 13, 2012 - 05:36:24 AM by hooD »
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
« Reply #2 on: September 13, 2012 - 09:45:59 AM »
Yes, the rear hose could be bad and not letting the fluid back through...holding the brakes on.  The first thing I'd do is make sure the brakes are assembled correctly.  If you are experienced in this I'll assume they are assembled right.  If not, post a pic and we can tell you if they are assembled correctly.  Whenever you do a rear brake job, it's good to replace all the springs.  Hardware kits are cheap.
Offline V02Barracuda
« Reply #3 on: September 13, 2012 - 12:48:28 PM »
This happened to me many years ago.  My parking brake cables were slightly hanging up but I didn't realize this at first.  I finally realized that the cables were not releasing and I replaced them.  Problem solved.  Not saying this is your problem but it's worth checking.
Rubber hose above the axle is a likely culprit too.  Those hoses are inexpensive and easy to change.
Good luck.
« Reply #4 on: September 13, 2012 - 08:05:19 PM »
Double check your e-brake cables.  :2cents:
Offline AARCUDADEN
« Reply #5 on: September 14, 2012 - 01:51:30 AM »
E-Brake cables were the culprit. All is good and thanks for the replies guys it sure helped pinpoint the problem  :2thumbs:
Dennis,Ohio
Offline Aracer
« Reply #6 on: September 16, 2012 - 01:48:13 AM »
 :2cents: Sometimes the problem is that the self adjusters ratchet up too much and, or, one side more than the other. It's the teeth/ lever area that wears. Wheel cylinders get sticky when old and over extended, so buy new ones all the time with the hardware kits and hose. Springs go a few times, but the pins are cheap to replace if bent or rusty. Clean and paint the E-brake levers and backing plate too.
Offline AARCUDADEN
« Reply #7 on: September 18, 2012 - 12:01:29 AM »
I replaced the wheelcylinders and all hardware a little over a year ago. E-Brake seemed a little lose to me so i adjusted it up. Come to find i adjusted it appartly too much  :P My own stupid mistake but all is well now  thanks to you guys  :2thumbs:
Dennis,Ohio
