Author Topic: Intake manifold machining question  (Read 708 times)
Offline RCCDrew
« on: September 13, 2012 - 02:44:35 PM »
I'm putting an rpm air gap intake on a 340 in my cuda. I don't know what's been done to the block and heads as far as machining. How can I determine if I will have to do any machining to the intake to get it to fit properly?
Thanks in advance.
Re: Intake manifold machining question
« Reply #1 on: September 17, 2012 - 01:55:17 AM »
is it hard t o figure out other than trying to bolt it  on , if you cannot get the bolts into the heads on both sides the intake is too wide
Offline RCCDrew
« Reply #2 on: September 19, 2012 - 04:12:45 AM »
Ok then.  It bolts on, I was mostly worried about a vacuum leak between the intake and head.
« Reply #3 on: September 20, 2012 - 02:01:36 AM »
if the heads are milled to increase compression the intake will be too wide to fit easily so if it fits you should be good
Offline sprecks
« Reply #4 on: September 20, 2012 - 07:35:40 AM »
I'm not sure about small block numbers but on a big block the rule of thumb was for every 0.030" milled off the head, 0.010" needed to be milled off the intake side.
you can call me Jay
I've seen sicker dogs get well.
1971 Challenger Vert - 472 Hemi EFI
1969 Road Runner 440/Auto
2017 Ram Laramie 1500 - Hemi
