Author Topic: Upgrading Tach & Clock to electronic  (Read 7862 times)
« on: September 13, 2012 - 09:33:44 PM »
Prowling the internet, I see that I can upgrade my Rallye clock to a Quartz conversion.
Also, Have the rallye Tachometer upgraded to a electronic self calibrating unit installed.
Can these be ordered: just the parts and have them installed locally?
I just want to try avoid a long L/T on them getting returned.
It would be nice if I can get those parts and have them installed locally.
Hayward speedometer could do it if I had everything.
Anyone done that before?
If you sent it out, how long a wait did it take?
Thanks
Offline LAA66
Re: Upgrading Tach & Clock to electronic
« Reply #1 on: September 13, 2012 - 10:24:10 PM »
 Not sure exactly what you're considering but the R/T Engineering tach replacement is fairly simple. Basically take it apart and solder 4 wires to the new board.
 I had the quarts clock done by a specialty business though and was none to happy with it.
« Reply #2 on: September 13, 2012 - 10:47:36 PM »
thanks for the input. What was your experience?
Offline cuda346pk
« Reply #3 on: September 14, 2012 - 01:45:33 AM »
I did both mine myself. Clock is simple. Tach would have been simple if I had a more standard ignition and the tach itself didn't need mechanical work. I used premium dash decals out of Canada. If your tach already works it will be a simple thing.
David - In Georgia
1972 'Cuda In-Violet 340 6 Pack 4 Speed 3.91 Sure Grip - Finally, after 27 years of waiting and dreaming it is real. Now the fun begins!
« Reply #4 on: September 14, 2012 - 02:04:26 AM »
Can you recommend where/what you bought and their prices?
I would like to do handle this very fast. Slow is not an option.
Offline LAA66
« Reply #5 on: September 14, 2012 - 08:34:42 AM »
 I sent mine to a guy calling himself the tachman. Dirty fingerprints all over the clock face. Tach failed immediately so I gave up and DIY  with the R/T eng tack unit. It worked well until I installed the FBO ignition which caused the tach to read high at idle. I read it is because the multiple spark pulses or some thing like that in certain ignition designs. R/T offered to replace the board I just haven't been motivated to pull down the dash again.
Offline cuda346pk
« Reply #6 on: September 15, 2012 - 03:35:39 AM »
http://premiumdashdecals.com/tachboards.htm
I dont see a link for the clock kit. I think I got it off ebay inder maybe his mrheaterbox name. Very easy to deal with but the international shipping slows it down. I got my voltage limiter from RT engineering they were good too.
David - In Georgia
« Reply #7 on: September 17, 2012 - 11:50:38 PM »
I tried contacting Real Time engineering 5 times by phone in the last 2-3 weeks. No answer.
Now their VM doesn't even pick up. Tried e-mailing them and it keeps bouncing. FYIcuda told me they did business with them 2 years ago.
Is this like playing the Lottery to get their business?
Perhaps they went out of business?
Offline cuda346pk
« Reply #8 on: September 18, 2012 - 03:23:56 AM »
I got my limiter from this this past winter. Seems like I had trouble getting in touch with him too.
David - In Georgia
Offline wally426ci
    • maryland mopars
« Reply #9 on: September 18, 2012 - 07:03:04 AM »
Mike, talk to CODY. He was going to school me on the working with the Clock once but I got lazy. I still need to fix that and my tach.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline 72ls5fla
« Reply #10 on: September 18, 2012 - 11:52:46 PM »
I had my clock converted and my tach refaced/upgraded about two months ago.
I used a service provided by Performance Car Graphics.  The owner David Patik, does the work.
Work was excellent and I could not be happier.
The pricing was very reasonable.
He is located in Tallahassee.
Here is a link to his website:
http://www.performancecargraphics.com/
Bill
« Reply #11 on: September 23, 2012 - 10:27:43 PM »
I did the upgrades to mine just ordered the parts , but if RTE is not answering that is hard to do
Offline 73EStroker
« Reply #12 on: September 27, 2012 - 06:18:20 PM »
My tach and clock conversions were RTE. install for the tach was borscht simple. The clock was a ***** I ended up using aviation rivets on the clock face and painting them flat black. That clock though, is bang on after 2 years plus running with no corrections. You will have to buy the tach exerciser though as it is impossible to know if you are calibrated correctly
Barry (Salmon Arm)
« Reply #13 on: October 07, 2012 - 08:48:39 PM »
http://www.performancecargraphics.com/Dash_Stuff/Restoration/70-74_E-body_Rallye.htm
Modern-day circuit board allows correct tachometer operation with MSD Ignition System (Multiple Spark Discharge)
What is a tach excerciser?
Offline 73EStroker
« Reply #14 on: October 09, 2012 - 04:48:41 PM »
R/T Eng sell the tach kit and they sell the exerciser. It does two things 1) it sweeps the tach needle from 0 to full scale 7000 or 8000 to wear in the tach as the new circuit board does not like to drive such a heavy movement type meter. I had mine doing this for about 2 days. Seems to work good. 2) it calibrates the tach to 1000 rpm and also calibrates to 4000 rpm as you do a lot of adjusting to get both right.
RTE say it is calibrated but mine was not the case straight out of the box.
Barry (Salmon Arm)
