News:
Correct.....you need an 18 spline disk for the new unit.
On the moparts thread, Jamie said he would re-hub 23-spline clutches to fit the 18-spline shaft.The same thread says that the shift mechanism & linkage will be different, but it will re/use the stock shifter handle(s).
Tommyg, why don,t you buy the 4speed od from Passon. I am only changing to the 5 spd because my car is not very drive able in the cities otherwise the 4 spd is perfect so 3rd gear is what I need for that
Top is that everything? To do a conversion from auto to 5 speed?
