Author Topic: Fuel gauge  (Read 1175 times)
daves70
Fuel gauge
« on: February 23, 2005 - 07:33:03 PM »
The rallye gauges in my challenger work fine except for the fuel gauge. It says I have half a tank of gas no matter what is in the tank. It seems to fluctuate but doesn't go up or down. Would this be the sending unit in the tank ot the gauge itself? Any help would be appreciated. Dave
Offline Burpin Chunks
  • http://mikescuda.net/cuda-challenger/burpin_chunks
Re: Fuel gauge
« Reply #1 on: February 23, 2005 - 08:34:40 PM »
probably not the answer you were looking for but it maybe the car. Try replacing it with a KIA and see if that corrects the problem.  :thumbs:
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
Re: Fuel gauge
« Reply #2 on: February 23, 2005 - 08:46:14 PM »
Gee, I thought we all knew that already Burpin (I am sad to say, I do own a Kia Sportage  :cry: )
Re: Fuel gauge
« Reply #3 on: February 23, 2005 - 09:03:15 PM »
YIKES  :laughup: :laughup: :laughup: :laughup: TISK TISK  :nono: :nono: :nono: :nono: just say no to the KIA
  • Global Moderator
Re: Fuel gauge
« Reply #4 on: February 23, 2005 - 09:06:06 PM »
Can I still delete my previous post???   :banghead:  :banghead:  :banghead:
Offline hemi71
Re: Fuel gauge
« Reply #5 on: February 23, 2005 - 09:26:24 PM »
crawl under the car, pull off the wire to the sending unit in the tank, and ground the conductor (a jumper wire to the frame in a spot that you can see shiny metal, you will probably need to scape it to make a good connection, or just run a piece of wire from the sending unit lead at the tank to battery negative) and check the gage...it should go to full. if it does, the gage is good and the sending unit is bad. If it stays at 1/2 tank, the gage is stuck. also, amke sure the jumper strap between the fuel line and the sending unit is there and making a good connection.
Offline JS27N0B
  • Member since Jan 28th 2003.
Re: Fuel gauge
« Reply #6 on: February 23, 2005 - 09:33:39 PM »
Also unplugging the sending unit should cause the guage to go to empty.
2013 Tige' RZR 343hp
