Author Topic: 1970 Cuda "Crush Can"  (Read 1351 times)
Offline Ca70Cuda
« on: September 17, 2012 - 09:46:18 PM »
Hello, I just installed a "Crush Can" on my 1970 Cuda. I made sure that the "Crush Can" was keyed properly with the double spline before installing. After the splines were lined up, I installed the "Crush Can" and tightened. However, after the "Crush Can" was tightened down, there is a gap between the bottom of the "Crush Can" and the steering column housing that supports the ignition switch. I do remember seeing a gap in other Cudas that have a "Crush Can".
OK, Here's my question: What is the typical (Average) distance of the gap between the bottom of the Crush can" and the steering Column housing?
I have attached a picture as a reference. Please note that I really tightened this as much as possible. I even removed the "Crush Can", re aligned the splines and reinstalled. Still have a gap.
Thank you!
« Last Edit: September 17, 2012 - 09:50:04 PM by Ca70Cuda »
2012 Blackberry Pearl RT Challenger
2011 Tungsten Rallye Challenger
1970 Cuda, Yellow
1969 Roadrunner, Orange
1969 Roadrunner, White
Offline 67vertman
  • Member since 9-23-2005
Re: 1970 Cuda "Crush Can"
« Reply #1 on: September 17, 2012 - 11:08:14 PM »
I just measured mine, it factory original, as-in never been removed, it measured 1/4 inch gap.  :2thumbs:
Offline Ca70Cuda
« Reply #2 on: September 18, 2012 - 11:40:04 AM »
Thank you! I do appreciate this. I will measure the gap later today. I think it is about 1/4 inch or maybe a little bigger. Thanks again!
« Last Edit: September 18, 2012 - 11:42:11 AM by Ca70Cuda »
1970 Cuda, Yellow
« Reply #3 on: September 18, 2012 - 04:08:25 PM »
Mine looks like your picture.    :grinyes:
Offline Ca70Cuda
« Reply #4 on: September 19, 2012 - 12:42:20 PM »
Thanks for your assistance. Good to know the gap is normal. I measured the gap this morning and it was just under a quarter inch so I think I am in the ball park. Thanks for all the help.  :thumbsup:
1970 Cuda, Yellow
