Author Topic: Rally Hood emblems  (Read 872 times)
Offline ff6849
Rally Hood emblems
« on: September 17, 2012 - 11:12:06 PM »
I have a rally hood for my Barracuda, unsure what year it is, it has two small holes in the raised portion on the faux hood scoops.  I am installing the hood on a 73 Barracuda with a 440, which 440 hood emblem would work on this hood, and were all the rally hoods hood emblem mounting holes the same from year to year.
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Offline dutch
Re: Rally Hood emblems
« Reply #1 on: September 18, 2012 - 01:42:12 AM »
mine has 440cuda emblems.  make sure you test fit them before paint, you may have to adjust the holes a bit... most non factory dont fit too nice.
*** Bart ***
Offline ff6849
« Reply #2 on: September 19, 2012 - 06:11:46 PM »
how are  hood emblems installed, never done it before.
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
« Reply #3 on: September 25, 2012 - 08:59:56 AM »
They just use a retainer with small lock tabs , they slide onto the pins & lock into the metal
« Reply #4 on: September 25, 2012 - 09:15:37 AM »
Barrel Nuts.....I found these at the local Ace Hardware.
