Author Topic: Carb tuning  (Read 555 times)
Offline Husker Cuda
Carb tuning
« on: September 18, 2012 - 11:42:50 PM »
Hey guys, I have had my 512 stroker at several car shows this summer and overall it runs great but it runs very rich and gets a whopping 6 MPG driving normally down the highway with 3:23 gears.  I have the Max wedge Indy EZ heads and a 10:5-1 compression block.  I have a 950 Quick Fuel mechanical secondary carb but no idea what jets it has in it.  I thought I would start with changing the jets but need to know what size you would recommend trying?  My current setup is a little soft on the bottom end but is a monster after 3,000 rpms.  I'm thnking if I get it leaned out a bit it will wake it up a little more.  I know It probably needs setup on an 02 meter to dial it in but I want to find a good starting point.
1974 'Cuda 512 stroker 650HP Indy heads, Hemi 4 speed, pistol grip - restored to new.
1970 GTX 440/727 Y4 Gold w/ black interior
1969 Camaro SS 396 4-speed X22
1970 Chevelle SS 396 - 375HP M22 4 speed
Re: Carb tuning
« Reply #1 on: September 19, 2012 - 12:10:33 AM »
I would pull the plugs & look for color first  , you can try dropping 4 sizes , good start if it id the right direction you will feel it .
It could have more to do with the bleedsfor the jet circuit , you may need to drill them or install larger bleeds , the inner bleed are jet outer are the idle
