Author Topic: dumb question of the day  (Read 1651 times)
« on: September 19, 2012 - 11:39:35 AM »
I initially filled the rad with distilled water and no antifreeze.  I didn't want to deal with antifreeze if I had a leak.  How much water will be left in a small block after the rad is drained?  If I just add a 50/50 mix I'll have too much water in the system.
Offline 4Cruizn
  • HEMI FISH
Re: dumb question of the day
« Reply #1 on: September 19, 2012 - 11:59:19 AM »
Why not add 100% antifreeze and a little more water?  There will still be some water left but not that much.   :thumbsup:
Offline LAA66
« Reply #2 on: September 19, 2012 - 09:47:19 PM »
  60/40 would seem right if you are keeping the challenger in a garage. Knowing you, it will be changed in a couple years anyways. :)
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #3 on: September 19, 2012 - 11:00:45 PM »
You could drain the block using the drain plugs on each side.  I would guess there might be up to 2-3 gallons of water in the block.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
« Reply #4 on: September 19, 2012 - 11:20:58 PM »
The engine mount brackets are in the way of the block plugs.  That would be the best thing to do but I can't get to them.  Maybe I'll just add a couple gallons of antifreeze to begin with before mixing.  I can test if for strengh once the level is up high enough.
« Reply #5 on: September 20, 2012 - 01:33:40 PM »
I would put in straight antifreeze, run the engine a bit, test with a hydrometer and adjust as necessary. I think about 65-75% of the system capacity is in the block/heater core.  :2cents:
Offline dutch
« Reply #6 on: September 20, 2012 - 03:34:24 PM »
may be a stupid question, but why anti freeze instead of coolant?
*** Bart ***
« Reply #7 on: September 20, 2012 - 05:09:52 PM »
Over here Bart, anti-freeze and coolant are in the same jug.
Offline dutch
« Reply #8 on: September 21, 2012 - 12:21:42 AM »
oh...ok ,thanks.   I think overhere you will have to really search for anti freeze.  all pre mixed  :2thumbs:
*** Bart ***
« Reply #9 on: September 21, 2012 - 06:19:54 PM »
you will have over 3 gallons in the system , draining just the rad would get you in the 60/40  [more water] zone so I would drain one side of the block & put in 2 gals of AF & top up with the drained water
« Reply #10 on: September 21, 2012 - 07:04:32 PM »
OK, thanks for the suggestions.  I'll take another look at the block plugs.
