Author Topic: Start Up Oil Pressure  (Read 634 times)
Offline AMXguy
« on: September 23, 2012 - 07:00:56 PM »
What would cause a good condition 440 to rattle and clatter for about 20-30 seconds on start up?  it misses and clatters then cleans up and runs great with more than enough oil pressure, about 70 psi cruise and 30 idle.
It's like a bad lifter, only it sounds like all the lifters.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Re: Start Up Oil Pressure
« Reply #1 on: September 23, 2012 - 07:28:28 PM »
sounds right , 4-5 lifters on the open valves will bleed down with valve spring pressure & it takes a few seconds to pump them back up .
Offline AMXguy
« Reply #2 on: September 23, 2012 - 09:12:32 PM »
But it's worse than it has ever been, lots worse.
the only thing different is the Joe Gibbs 20-50 oil and a Bosch filter.  would the heavier oil make it bettwer or worse or any difference? and do these type filters have a backflow valve?
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #3 on: September 23, 2012 - 09:54:55 PM »
probably the thicker oil would make it worse , cold 20-50 flows slowly
