They make pretty much everything now except the convertible specific sheet metal. The doors will work. They make the cowl peices, the door pillars, rocker patch panels, quarters, wheel houses. The outer wheel houses for a hardtop can be modified to work for the convertible but the inners and the upper portion are very different and hopefully the ones on the car can be patched. This car will need a ton of work and lots of money to restore. Unless you have most of the parts already and can do all your own work you're better off buying one done at this point. All these convertible projects are coming out of the woodwork these days for a reason.
