Author Topic: K member question  (Read 586 times)
Offline Jimmy
  • THE Challenge(r)
K member question
« on: September 24, 2012 - 09:23:40 AM »
I have a 73 Challenger and a 71 Charger. Both originally had small blocks, thus they have the small block K members. I plan on putting 440's into both. Do I have to have the big block K member, or will the 440 match up with the small block K member? What is the difference between the two? Just trying to educate myself before I head down a wrong path. Thanks!
1973 Challenger w/440
1967 Camaro RS w/502
1967 Mustang w/302
1965 Ford F100 w/429
Offline ksierens
    • 70 Challenger Resurrection
Re: K member question
« Reply #1 on: September 24, 2012 - 09:39:53 AM »
You can buy conversion motor mounts from here:
http://www.engine-swaps.com/Pages/ProductsYear/70.74eBody.html
Kurt - SE Michigan
Offline Jimmy
  • THE Challenge(r)
« Reply #2 on: September 24, 2012 - 09:51:07 AM »
Awesome! Thanks Kurt!
1967 Mustang w/302
« Reply #3 on: September 24, 2012 - 10:31:54 AM »
the K frame is the same for all V8s except the Hemi so all you need is the engine mount , there were difference to the K frame as the Hp engines have skid plates to protect the deeper oil pan , the skid plate can be welded on to any V8 k though
