Author Topic: PCV Noise  (Read 1357 times)
Offline 70challengersix
PCV Noise
« on: September 25, 2012 - 11:48:40 AM »
Has anyone experienced a PCV valve noise at low RPM/Idle.  I have changed mine out for a second time and the noise continues.  Sounds like a belt "chirping" and goes away when I disconnect the PCV valve and plug the vacuum line.  Its a 440 six pack setup.
Re: PCV Noise
« Reply #1 on: September 25, 2012 - 12:10:48 PM »
you maust have just the right amount of vacuum to cause it to flutter so how to fix it  ? restrict the hose with a nut inside maybe ?
Re: PCV Noise
« Reply #2 on: September 25, 2012 - 03:49:18 PM »
I think there are PCV valves with springs, and without. Whatever you have, maybe try the other type and see what happens.
Offline Chilly
Re: PCV Noise
« Reply #3 on: September 25, 2012 - 05:40:24 PM »
PCV valves are made with different orfice size depending needs for engine. You may want to use a top quality valve, some aftermarket valves will cause this fluttering sound.  This will also have a effect on how the car idles at times.  Chilly
