How Bad Do You Want It.
I would do a title search on the AAR. If you decide to purchase it, deduct the cost from the purchase price.
Without a build sheet or vin tags I wouldn't purchase.
It had to be repainted. The stripe would be worn, especially the AAR emblem on the quarter panels.
Maybe the front was wrecked and the front support was replaced,
Under the hood the inspection holes should be black. Not body paint.
http://i776.photobucket.com/albums/yy48/jddrywall/2012-09-27_09-48-56_218.jpgIs the radiator correct?
Cowl hood weather strip not original.
I would say most AAR's had a standard dash not Rallye.
The Rallye dash is not correct.... Missing barracuda emblem on dash. Rivits not correct for dash vin tag.
I don't see a day/night mirror. It does have power steerng, correct looking master cylinder, 3 speed wipers but it is black, duel mirrors..
Cuda Hunter checked the engine said it is numbers matching. That is most important matching the vin and motor. Does it have the correct heads,
with the adjustable rocker arms?
AAR's are selling between 50 to 85 thousand. If this AAR was correct 75 would be acceptable with that color.
