Author Topic: Anyone else try electrolysis for Rust Removal?  (Read 1260 times)
Offline the_engineers
« on: September 27, 2012 - 02:13:09 PM »
I'm terrible at taking pictures, so bear with me.
Several years ago, I found out about using electrolysis for rust removal.  Basically, you use your rusty part for "donor" material and "plate" a clean (scrap) piece of metal with rust.  I first did this on an iron table saw top and was amazed.  On our current project, I've used it for caliper adapters, a 742 housing, spindles, and my rear axle pieces.
Like I said, I'm terrible about pics.  Here is the axle housing going into the bath.  The rear dome was the only part that wasn't complete rust.
Here is the after from soaking overnight:
I still had to scrub the crap off of it with a Scotch-Brite path, but no more effort than you would spend on a dirty dish.
This will also remove grease and paint.  As the iron starts to move, anything that is on the surface is cast off.
Here's the kicker...100% safe, cheap and extremely effective.  Everybody raise their hand.  Lower your hand if you don't have a battery charger.  Lower your hand if you don't have have some scrap steel.  Lower your hand if you can't get Washing Soda at the store (Walmart carries it.  Laundry aisle).  Lower your hand if you don't have water.
If your hand is still raised, you're in business.  Directions are here: http://antique-engines.com/electrol.asp
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Re: Anyone else try electrolysis for Rust Removal?
« Reply #1 on: September 27, 2012 - 02:16:21 PM »
I have a "before" pic.  Axle from my housing.  BTW, the PO drained the axle of any lubricant and then set it outside for storage.  Hot, cold, condensation...you get the idea.
I'm going to give it 2 hours at 20 amps, scrub and post some pics.
Brooks
1971 'Cuda 360
Offline dutch
« Reply #2 on: September 27, 2012 - 03:19:18 PM »
wow...that looks great.....  :popcorn:
*** Bart ***
Offline Barracudadan
« Reply #3 on: September 27, 2012 - 05:40:12 PM »
I used this method on one end link bracket for a rear sway bar setup I have the results were fantastic. I still have to do the other one just havent got around to it yet. I can try to post before and after pics for comparison, but I always have problems when I try to post pics here for some reason.  :dunno:
Here is a link for a simple homemade soda blaster. http://www.aircooledtech.com/tools-on-the-cheap/soda_blaster/  I never tried it yet but I want to. The before and after photos of the Porsche carbs are amazing! If anyone tries this post up the results.
« Reply #4 on: September 27, 2012 - 09:04:27 PM »
I had to run to the store, so it ended up baking for about 4 hours...  Hey the axle bearing freed up!
« Last Edit: September 27, 2012 - 09:10:05 PM by the_engineers »
Brooks
1971 'Cuda 360
