Author Topic: Switched power source  (Read 899 times)
Offline 67vertman
  • Member since 9-23-2005
« on: September 30, 2012 - 07:09:11 PM »
I need switch power, in the start and run positions, for my electric fuel pump and MSD coil, where is the best place to get this?
I would like to tap into the fuse block, if possible.
Re: Switched power source
« Reply #1 on: September 30, 2012 - 08:26:05 PM »
the only place both come together is either at the bottom of the column or at the ballast resister brown is start , blue is run
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #2 on: September 30, 2012 - 08:38:43 PM »
From whatever source you get power only use it to activate a solenoid.  Get the power for your pump off the starter relay terminal.  This will help keep load off the bulkhead connections which are weak to start with.
The Brewmaster
Offline 67vertman
« Reply #3 on: September 30, 2012 - 09:46:54 PM »
Yes, I am running the 12 volt power from the starter relay to a relay in the trunk, I also need to run a swithced power to the relay as well.
Offline 67vertman
« Reply #4 on: September 30, 2012 - 09:49:28 PM »
Neil, I tied those together to run the MSD. Do you think I could also tap into those to run a switch to the relay for the electric pump?
« Reply #5 on: October 01, 2012 - 08:22:34 AM »
Sure , the load to switch a relay is minimal
Offline 67vertman
« Reply #6 on: October 01, 2012 - 10:24:20 AM »
 :2thumbs:  Thanks Neil!
« Reply #7 on: October 01, 2012 - 10:47:21 AM »
Anytime !!
