Author Topic: 70 Challenger electric choke best source  (Read 633 times)
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« on: October 04, 2012 - 12:28:30 AM »
I have a new engine harness for my 70 and don't have (haven't seen) an electric choke wire. I looked at my father-in-laws 68 RR and he upgraded the car with an Edelbrock carb with an electric choke. His is connected to the alternator (blue I think) wire. I'd like to hook mine (later model thermoquad) to the same place since it's easy and close. I did a measurement and see that only one (green) of my wires was hot with the key but only had ~1.2v and not ~12. I suspect this is because of the ballast resistor.
My question, is this a good source? Is there a better one? What is the recommendation. It'd be nice not to have to run back to the fuse block.
Thanks again.
Re: 70 Challenger electric choke best source
« Reply #1 on: October 04, 2012 - 08:31:38 AM »
the blue wire is switched 12v , goes to the ballast , voltage reg & the alt field
Offline peterro
    • The Pistonhead
« Reply #2 on: October 04, 2012 - 10:57:37 AM »
So I'm clear, is it reasonable to connect the choke to the alt field? Just want to make sure it's not problematic.
Thanks again.
Offline peterro
    • The Pistonhead
« Reply #3 on: October 05, 2012 - 12:34:38 AM »
I apparently didn't get it measures right the first time. My blue wire is definitely hot with the key. The choke is now connected.
Thanks.
« Reply #4 on: October 05, 2012 - 01:40:46 AM »
 :2thumbs:
