Sometimes. you can access the secondary throttle blade adjustment and crack the secondaries enough that you don't need to drill the primaries and some of the newer carbs feature enough adjustment in the air bleeds that you can make the necessary adjustments. Get on the net, I've seen lots of articles in the press- Hot Rod, Car Craft, Popular Hotrodding about this. Good luck!
