Author Topic: Wanted: 1970 Challenger - Wiper Switch Connector Plug. (FOUND .... THX).  (Read 1788 times)
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
I have a 72-74 rallye dash harness in my 70 Challenger.   I searched long and hard to get a 1970 specific wiper switch .... rare and expensive.  Finally found one ...... now the harness plug for the wiper switch won't fit.    I guess when they moved to the newer switch, the old one was no longer used.
Does anyone out there have a beaten up old rallye harness with a plastic plug that I could swap out my later version for?
Thanks .... CHAPS
« Last Edit: December 10, 2012 - 10:26:22 PM by chaps70rt »
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
Re: Wanted: 1970 Challenger - Wiper Switch Connector Plug.
« Reply #1 on: October 07, 2012 - 08:57:43 PM »
I'd contact Slotts? ( Jim)
Offline chaps70rt
« Reply #2 on: October 09, 2012 - 07:38:50 AM »
Okay ..... thanks Brad.   I checked with Evans Wiring .... no luck there.
BTW .... do you know where I can find the sway bar retainers that hold the rod and bushings??   Can't seem to find a source?
Thanks .... CHAPS
440 - 4BBL - Shaker
« Reply #3 on: October 09, 2012 - 07:47:21 AM »
Thanks .... CHAPS
I assume your wanting stock ? ( for the sway bar?)I don't know where to find new ones?  I gave my stock sway bar to a member on here and lost one of the sway bar bushing brackets . After he picked it up I found it? So I have one stock one here you can have if your stuck?  If your going aftermarket then lots of options? Energy suspension etc....
Offline chaps70rt
« Reply #4 on: October 22, 2012 - 08:59:23 PM »
Thanks Brad ..... turns out that R/T Specialties has them.  $25 for the pair ..... so I ordered those.
Cheers ..... CHAPS
440 - 4BBL - Shaker
« Reply #5 on: October 23, 2012 - 07:29:15 AM »
Cheers ..... CHAPS
 :2thumbs:
Offline chaps70rt
« Reply #6 on: October 26, 2012 - 08:52:02 AM »
Still looking .... no luck with Slotts.
440 - 4BBL - Shaker
Offline YYZ
« Reply #7 on: October 26, 2012 - 10:50:43 PM »
CHAPS, I'm sure I have a '70 parts harness here that will have what you need, I will check tomorrow.
Offline chaps70rt
« Reply #8 on: December 02, 2012 - 10:12:04 AM »
Thanks YYZ ...... any luck finding that old wiper connector?
CHAPS
440 - 4BBL - Shaker
Offline MY J0B
« Reply #9 on: December 02, 2012 - 10:20:06 AM »
I have a 1970 NON-Ralley dash harness....Would that work ?
Offline tuff340GranCoupe
« Reply #10 on: December 02, 2012 - 10:28:44 AM »
I have one, in fact I have 3 70 E-body 'parts' wire harnesses. I would get you both connectors for your switch. You need just the plastic plugs or would you like a few extra inches of the wires from the plugs as well? $22 shipped to your door in the USA. Let me know: redbarron89 atmsn dotcom
Offline rave_12000
« Reply #11 on: December 02, 2012 - 11:02:23 AM »
got one...in case someone else doesnt pull through. thanks, mike
Offline JayBee
« Reply #12 on: December 02, 2012 - 11:11:35 AM »
Yes it will, as long as you're sure it's a '70. I converted my 1970 standard dash with 2 speed wipers over to a rallye dash with variable speed wipers and DID NOT have to replace the wiper plugs.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline MY J0B
« Reply #13 on: December 02, 2012 - 01:23:50 PM »
I'm 100% certain that the one I have is an original 1970 NON rally dash, but the car only has 2 speed wipers. You can have the whole harness for $30.00 if you pick it up.
Offline VTMopar
« Reply #14 on: December 02, 2012 - 04:03:17 PM »
Chaps:     I'm in the midst of doing the same thing.    From the research I've conducted - the '70 standard (non-rallye) wiring works for a 3 speed/variable switch.    I haven't installed my switch yet - I'm in the middle (like -- today) of trying to get the wiper transmission arms installed (actually looking at a website to see how the pivot arm installs to the wiper arms).   Were you able to score a set of these?
VT Mopar
VT MOPAR
