Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Steering shaft u joint ?
« previous
next »
Print
Pages: [
1
Author
Topic: Steering shaft u joint ? (Read 699 times)
stinger
Jr. Member
on:
October 09, 2012 - 07:39:35 AM »
my steering shaft coupler rubs on a header pipe and is getting cooked by the heat so I'm considering a u joint. what size would work and are there any issues running a u joint over the stock coupler?
Thanks!
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Steering shaft u joint ?
Reply #1 on:
October 09, 2012 - 10:32:34 AM »
it can be done , Borgeson makes steering U joints , I recommend both welding & pinning them , drill a hole into the shaft & insert a pin to prevent failure , the U joint will be smaller diameter but you may have to increase the shaft length .
Logged
stinger
Jr. Member
Reply #2 on:
October 09, 2012 - 12:33:09 PM »
Thanks,sounds easy enough.any problems running one on a stock colum due to flexing?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
October 09, 2012 - 07:18:39 PM »
I cannot see why the U joint would be ridgid on the steering box & the column shaft has only 1 brg @ the top & can float a little inside the column
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
