Author Topic: Another white smoke question  (Read 1473 times)
Offline NCtrueconservative
« on: October 09, 2012 - 04:52:26 PM »
Hey guys, quick question,
My 73 chally has white smoke that comes out the tailpipe.  I drive it every week, and it runs like a top, plenty of power- so I wouldn't think its a blown head gasket.  The engine has been rebuilt and it probably has less than 1300 miles on it. Could it be the rings not seated?  But again, plenty of power, runs great.  It seems to come out of both tailpipes when I start it up.  It fades away as the motor warms up, but then when I drive it, it starts again.  When I drive it, it seems to come out the passenger side the most, but still comes out the drivers side as well. It smokes the most when I go down hill, when I let off the gas.  When I get back on the gas, it seems to stop.  And after I level off after going down that hill, you can see some of the smoke in the interior of the car when you're driving.  Going up hill doesn't seem to make it smoke either.  So idk, it doesn't affect how it runs.....oh btw, I have flowmasters at the back, behind the valance. No resonators or anything, just flowmasters at the back. I was thinking it could be water steaming off in the muffler, but looks like it would stop after a while.  I'm running straight water right now as well.  Oil doesn't look milky to me.
1973 Dodge Challenger Rallye (pictured), 340, Slap Stick
1998 Dodge Ram, 5.2, Black, tinted windows, dual exhaust, blackout headlights, tailights
Re: Another white smoke question
« Reply #1 on: October 09, 2012 - 05:09:07 PM »
So when you take it out for a spin, how long are you driving it?
« Reply #2 on: October 09, 2012 - 07:27:30 PM »
The longest ive drove it one way before parking is 45 min
« Reply #3 on: October 09, 2012 - 07:30:46 PM »
for sure the rings are not seated & going downhill with the throttle closed will make some wicked vacuum so you are probabaly getting some oil smoke , moisture is normal out the pipes
« Reply #4 on: October 09, 2012 - 08:45:25 PM »
About how long does it takes for the rings to seat?
« Reply #5 on: October 09, 2012 - 09:48:29 PM »
depends on the type of ring & oil but 2-3000 miles to fully seat is possible
« Reply #6 on: October 14, 2012 - 08:42:45 PM »
How is your coolant level?
Offline jimynick
« Reply #7 on: October 14, 2012 - 11:19:43 PM »
Why screw around with it? If you put a coolant system pressure tester on it, pump it up to 12-13lbs and see if it sinks in a 1/2hr. That'll narrow it down if it doesn't lose pressure. Good luck.  :2cents:
Offline 72bluNblu
« Reply #8 on: October 15, 2012 - 12:40:37 AM »
What kind of valve seals are on it? Did it get new guides and seals with the rebuild?
