Author Topic: 440 with AAR Hood.. What is the tallest intake I can use?  (Read 2031 times)
Offline OUTRUNM
« on: October 10, 2012 - 08:00:12 PM »
I will be installing a 440 in my 73 and I just picked up an AAR hood what is the tallest intake I can use with this hood on the car?
1973 BARRACUDA
2006 SALEEN MUSTANG
2006 MONTE CARLO SS
1999 CHEVY PU
1976 PORSCHE 911 S 3.4 RS
1929 FORD MODEL A
Re: 440 with AAR Hood.. What is the tallest intake I can use?
« Reply #1 on: October 10, 2012 - 08:17:44 PM »
It is a trade off taller intake = smaller air cleaner , better question what intake best suits you engine build ?
Offline OUTRUNM
« Reply #2 on: October 10, 2012 - 10:37:53 PM »
Haven't got that far yet..  so far I have a 440 with a 727 out of a 1975 pickup ...I picked up a set of BME rods I would like to use.. as far as the build i would like a big chunky cam. was thinking about steath heads? Intake maybe a team g
 or ? .. any help sorting this stuff out would be great...  i was given the option of picking up a set of 915 or 906 heads today my choice for $200 the 915 have about 500 miles on them...
1973 BARRACUDA
2006 SALEEN MUSTANG
2006 MONTE CARLO SS
1999 CHEVY PU
1929 FORD MODEL A
Offline mojavered
  • Someday!
« Reply #3 on: October 10, 2012 - 10:47:10 PM »
Tons of different build options on here.  There is also a section of proven builds separated by bb/sb/Hemi.  Check it out, good place to start.
Jason
« Reply #4 on: October 10, 2012 - 10:59:19 PM »
My choice will always be the 915 heads
 Team G is OK , I would use the Mopar M1 over it though  , for a lower intake that fits under hood the Street Dom is awesome , everything needs to match though so we need to figure out what RPM you want to make power then get a cam & intake to work with that .
Offline OUTRUNM
« Reply #5 on: October 11, 2012 - 12:21:25 PM »
I'm thinking 3500 T0 7000ish?  What do you think?
 Here is the deal.. and I might sound kinda like a child he but here it goes..
  a friend of mine has this 67 ford fairlane with a 351w Keith black pistons eddy rpm heads and eddy rpm cam
hooker headers holley 750 carb  and 410 or 411 gears  ... the car runs like a bat out of hell and I want to be able to dust him .. not by a little but really whip his ass.. LOL
1973 BARRACUDA
2006 SALEEN MUSTANG
2006 MONTE CARLO SS
1999 CHEVY PU
1929 FORD MODEL A
« Reply #6 on: October 11, 2012 - 04:09:01 PM »
So you want a stock 440 then
  I beat up a "Fast"  69 stang with a roller cam 351 using a smog 400 , [1 cylinder only had 17 psi compression !!] in a 69 Dart !! while I didn't win , I also didn't lose , we tied 3 races in a row but if I had had all 8 cylinders he would have been toast !!
 So I assume this will be a street car , so you want a long flat powerband with a lot of torque , I would recommend a 512 ci stroker build with a powrband 2500 - 6500 ish this way you can drive it anywhere & still kick butt
Offline OUTRUNM
« Reply #7 on: October 11, 2012 - 08:03:14 PM »
what about eddy rpm heads are they any good?
1973 BARRACUDA
2006 SALEEN MUSTANG
2006 MONTE CARLO SS
1999 CHEVY PU
1929 FORD MODEL A
Offline PlumCraZRT
« Reply #8 on: October 12, 2012 - 10:20:46 AM »
Edelbrock heads and Stealth heads are both pretty good.  Keep in mind, you should go through the hardware and have the Stealth heads inspected before you install them.
A better, more expensive route is Indy heads.  They have raised exhaust ports, so not everything is quite as simple as the Edelbrock/Stealth route.
mmmmm.... Mopar.... *drool*
Offline barracuda7199
  • needs a resto but having to much fun right now
« Reply #9 on: October 13, 2012 - 07:57:36 AM »
i have a mopar m1 single plane intake on my 440 with an AAR hood on my cuda it fits fine not even close to hitting anywhere
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
« Reply #10 on: October 14, 2012 - 12:48:55 AM »
I feel the Stealth are as good for less $$ spent over the eddy , I also agree the indy are more $$ but worth it
Offline Road_Runner
« Reply #11 on: October 14, 2012 - 01:07:29 PM »
Have you thought about sealing the aircleaner to the underside of the hood with foam like they did with the AAR cars running that hood?  If you run a six pack you could possibly use a stock or reproduction AAR air cleaner (not sure if carb height is the same on a 340 & a 440 six pack, anyone?).  That would look totally cool and the 'fresh air' aspect of the hood wouldn't be wasted.  That is my favorite Cuda hood by the way.  If I ever decide to go away from a 'stock' appearance I'm getting one, too.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline OUTRUNM
« Reply #12 on: October 15, 2012 - 02:22:15 AM »
Okay well I bought a TM7  hope it fits... :thumbsup:
1973 BARRACUDA
2006 SALEEN MUSTANG
2006 MONTE CARLO SS
1999 CHEVY PU
1929 FORD MODEL A
« Reply #13 on: October 15, 2012 - 08:17:22 AM »
Later, Jim
That's more or less what I did , but with a single 4bbl. I got the custom base from here....
http://www.hybrid-fiberglass-solutions.com/
Offline Road_Runner
« Reply #14 on: October 16, 2012 - 09:44:55 AM »
And your T/A hood is my favorite Challenger hood.  I like them more than the shakers because they just stand out more and fit the cars perfectly.  If mine was a 70 I'd do an AAR clone in a heart beat, but I'm not as sure about a 73 AAR Cuda!
Later, Jim
