Author Topic: Anyone buy the brand new E-body tachometers available?  (Read 4971 times)
Offline KillerBee
« on: October 12, 2012 - 08:48:32 AM »
My original tach, like most, is reading waay high.
Going over my options.
First is to buy the upgrade kit and messing around trying to install and calibrate it or sending it off to have the upgrade installed for me.
Then I still having an old looking tach unless I get the face restored.
I'll have quite a bit of $$$ tied up in it.
The other option is to buy one of the new ones currently available for $200
I believe they are made by Charger Specialties, see the link below.
According to the link the tach works with points ,factory electronic ingnition or multiple spark, like MSD
Has anyone bought one of these?
How did it look and/or work?
Any info or suggestions would be appreciated. :thumbsup:
http://www.whitegauges.net/products/1970%252d1974-Rallye-E%252dBody-Reproduction-Tachometer-Gauge.html
« Last Edit: October 12, 2012 - 09:23:24 AM by KillerBee »
Offline Jocigar
Re: Anyone buy the brand new E-body tachometers available?
« Reply #1 on: October 12, 2012 - 09:44:51 AM »
 :popcorn:
« Reply #2 on: October 12, 2012 - 10:16:18 AM »
They work great. I had one for a year or two until I sent my original out for a rebuild. If you look at it closely, all the numbers are equal distant apart. The stock tach(pictured above), has the 0-1 close together with the biggest distance between 7-8.
As for working, it is much more responsive, as it doesn't have a heavy needle like the originals.
Offline KillerBee
« Reply #3 on: October 12, 2012 - 10:30:11 AM »
I see what you mean about the spacing of the numbers on the repop tach.
If you view the tach at the link I posted the difference is obvious.
Did the tach fit in the dash OK?
Wired up same as stock?
Did the colors on the new tach match the rest of the old gauges?
Thanks.
« Last Edit: October 12, 2012 - 10:40:51 AM by KillerBee »
Offline ragtopdodge
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline KillerBee
« Reply #5 on: October 12, 2012 - 10:44:01 AM »
This repop is more close to resembling the original than the link you have above:
http://www.ebay.com/itm/1970-1974-Cuda-Challenger-E-body-Rallye-8K-Tachometer-Gauge-NEW-Mopar-/370640213643?fits=Model:Cuda&hash=item564be0d68b&item=370640213643&pt=Vintage_Car_Truck_Parts_Accessories&vxp=mtr
That's the pic I had in my original post from the same E-bay ad from Dante's
I have a feeling the new tachs are all made by Charger Specialties and have evenly spaced numbers unlike the factory one in the pic.
If you click on the link I posted above you can enlarge and view a pic of the repop tach and see the difference in the number spacing.
« Last Edit: October 12, 2012 - 10:50:11 AM by KillerBee »
Offline ragtopdodge
« Reply #6 on: October 12, 2012 - 10:50:18 AM »
No, I think Charger Specialties was the first to come out w/repops, but they are not accurate looking.
I think some other outfit started making repops that more closely resembles OEM.
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline KillerBee
« Reply #7 on: October 12, 2012 - 10:54:19 AM »
Sounds good to me.
I'm gonna contact Dante and ask.
If the repops do look that accurate and work that good for $200, why bother restoring an old original. :dunno:
Update
Per Dante (the e-bay seller), the repop tach he sells is exactly like the one pictured in his ad so the number spacing does look like the original tach.
« Last Edit: October 12, 2012 - 11:49:55 AM by KillerBee »
« Reply #8 on: October 12, 2012 - 03:29:10 PM »
Thanks.
Yes,
Yes,
And yes. I just wanted to point out the slight differences to you if you wanted your gauges to look stock. I see the E-Bay ad posted above is an improvement over what I bought.
Offline Katfish
  • 70 Challenger
« Reply #9 on: October 12, 2012 - 03:41:47 PM »
Good info,
All things considered, I'd think you'd get more accurate readings with the wider spacing?
Seems like you'd lose resolution at the lower RPMs with the smaller spacing, which is where I'd think we'd used it the most.
Offline KillerBee
« Reply #10 on: October 12, 2012 - 04:16:12 PM »
Good info,
Yes I agree the wider spacing would be easier to read but in all honesty I've used an RPM activated switch to activate a factory light on my dash at my shift points on all my cars for many years.
Never was able to accurately watch the tach needle and run/race my car hard, especially with a 4 speed.
I also have rev limiters on them.
Having a hidden shift light is so much safer, easier and more consistant. :2cents:
I've outgrown the huge aftermarket tach and other gauges and like my dashes to be stock looking and uncluttered so I would like to have a factory looking tach that will be accurate even if I only look at it occasionally. :thumbsup:
« Last Edit: October 12, 2012 - 04:22:39 PM by KillerBee »
Offline Katfish
  • 70 Challenger
« Reply #11 on: October 12, 2012 - 04:24:26 PM »
Post what you end up doing, I'd like to upgrade my tach as well.
The orginal works, but is just sluggish.  I like the idea of a modern, accurate, responsive tach.
Offline KillerBee
« Reply #12 on: October 12, 2012 - 04:33:01 PM »
I plan on buying one.
Winter is almost here in my area so it's time to store the old cars.
I've been E-mailing with Dante's Performance and have bought from him in the past.
He has a sale coming up around the holidays so I plan to have few things to buy then including the tach, unless I find it on sale before then.
« Last Edit: October 12, 2012 - 04:37:24 PM by KillerBee »
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #13 on: October 25, 2012 - 05:45:14 PM »
http://www.rosevillemoparts.com/product_info.php/p/70-74-e-body-rallye-dash-8k-tachometer/products_id/7204
nice pieces, we do carry the gauges and havent had any issues with the E or B body
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline CUDA JAS
  • vroooooom!
« Reply #14 on: October 25, 2012 - 10:02:28 PM »
Good info,
But the smaller spacing is only between 0 and 500 rpms...which you never use anyway.
The pics that mopardave posted look acurate!!
jaosn
74 'cuda 360/727
Just call me a gearhead!
