Author Topic: Over or under frame brake lines?  (Read 1333 times)
Offline 1970A66D21
  • Livin in Vegas
« on: October 12, 2012 - 11:33:27 AM »
My 1970 Challenger is an October 1969 built car.What front brake line kit should it have .Over or under the frame?  Thanks
Offline shawge
  • Zoiks!!
Re: Over or under frame brake lines?
« Reply #1 on: October 12, 2012 - 12:24:04 PM »
Mine was an Aug. 1969 build and it was originally an under.
Curious as to which vendor are you using for the lines (Fine Lines, Inline, ??).  I need to pick up a set.
- Jerry
Offline dutch
« Reply #2 on: October 12, 2012 - 12:26:32 PM »
drums had over frame and discs had under. Not sure if power brakes made a difference.
*** Bart ***
Offline shawge
  • Zoiks!!
« Reply #3 on: October 12, 2012 - 12:38:52 PM »
Hmm, I guess I should have stated that my car originally had power drums on all four corners.
- Jerry
Offline 71hcc
« Reply #4 on: October 12, 2012 - 01:01:18 PM »
Some food for thought, if correctness is not an issue and you are running headers the over the frame lines will move the lines away from the heat of the header tube. It may not be problem with a small block but with my hemi there is one header tube that is right next to the brake line where it crosses under the frame rail, not much more than a 1/4 of an inch clearence. That is with hookers, it may not be an issue with the set of TTIs that I bought but I have the car apart for a repaint so I haven't installed them yet. But I know the TTIs tube routing is entirely diffrent than the Hookers.
Jim
« Last Edit: October 13, 2012 - 12:47:05 PM by 71hcc »
Offline 1970A66D21
  • Livin in Vegas
« Reply #5 on: October 12, 2012 - 02:05:15 PM »
My car has manual drums all around.Has manual everything.
I am looking at a Fine Lines complete kit.
