Author Topic: Replacing 4 speed reverse light switch  (Read 843 times)
Offline KillerBee
« on: October 13, 2012 - 10:37:25 AM »
Picked up a new reverse light switch to replace the leaking original one in my 4 speed.
Should I be prepared for tranny lube to leak out when I remove the old one?
Thanks.
Offline FY1Cuda
Re: Replacing 4 speed reverse light switch
« Reply #1 on: October 13, 2012 - 11:13:17 AM »
Yeah, the gear oil will leak out, so move fast.  When we put a switch into ours, the button wasn't being pushed in far enough to light the reverse light.  Had to pull it out and machine off a little of the shoulder so it seated in further.  Hope your's works out of the box.
Offline KillerBee
« Reply #2 on: October 13, 2012 - 01:54:17 PM »
Thanks, that what I figured, at least I'll be prepared.
Do you remember what swith you installed? a NOS type or the newer type.
The one I pictured is the newer type, supposed to be better at not leaking where the wired plug goes in.
« Reply #3 on: October 14, 2012 - 12:52:37 AM »
I have never had a problem with the newer / better switch , if you jack up the rear of the car you may lose less fluid
Offline KillerBee
« Reply #4 on: October 14, 2012 - 03:28:21 PM »
Got it swapped out.
The new switch works perfectly.
Drained the fluid to avoid a gear lube shower mess.
I also wanted to be able to inspect/clean the threads.
Pumped the fluid back in with a handy suction tool I picked up cheap at the auto
 parts store.
http://www.oreillyauto.com/site/c/detail/PFM0/W54220/N0727.oap?ck=Search_suction_N0727_-1_2396&keyword=suction&pt=N0727&ppt=C0139
« Last Edit: October 14, 2012 - 03:30:46 PM by KillerBee »
« Reply #5 on: October 14, 2012 - 03:39:06 PM »
 :2thumbs:
