Author Topic: Wire harness need to change or not?  (Read 1021 times)
Offline Mark8117
« on: October 16, 2012 - 10:06:28 PM »
71Challenger going from a 318 to a 440, do I need to change the wire harness
Re: Wire harness need to change or not?
« Reply #1 on: October 16, 2012 - 10:16:04 PM »
That's an obvious yes. The distributor wires are in the back on LA blocks and the B/RB blocks are in front.
You could splice/crimp to lengthen and whatever others need that too. But why bother?
« Reply #2 on: October 16, 2012 - 10:38:36 PM »
 the wire to the coil ,  temp sensor & the alt wiring needs to be extended also
 Not hard to extend the wires using solder & heat shrink though if the harness is in good condition
« Last Edit: October 17, 2012 - 07:56:42 AM by Chryco Psycho »
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: October 17, 2012 - 01:29:52 AM »
I replaced everything except the dash wiring harness.
Offline Mark8117
« Reply #4 on: October 18, 2012 - 07:30:09 PM »
Great thanks for info.  I'm new to Ebody, I've had an A body for the last several years.
